Author Topic: FRONT TURN SIGNALS ON MY '74  (Read 3156 times)
Offline kfoz
  • ALWAYS BUILD WITH BRICK & STONE ! ! !
« on: November 03, 2008, 10:47:25 pm »
WHAT MAY BE THE PROBLEM HERE??? MY DRIVERS SIDE FRONT TURN SIGNAL WORKS BUT THE RUNNING LIGHT PART OF IT DOES NOT! THE BULB IS GOOD. MIGHT THERE BE A GROUND ISSUE OF SOME SORT? THE WIRING LOOKS GOOD.  ANY HELP IS APPRECIATED!
kfoz
kfoz (kfoz@comcast.net)
'73 C20 4 Speed 2WD
Re: FRONT TURN SIGNALS ON MY '74
« Reply #1 on: November 04, 2008, 05:11:09 am »
Bust out a test light and check. Do you have B+ at the parking light? If so it is your ground at fault.
