Engine/Drivetrain
Clutch issues HELP
Topic: Clutch issues HELP (Read 5324 times)
greenkeeper
Clutch issues HELP
November 07, 2008, 10:21:47 pm »
I have an 87 R-30 Customdeluxe 1 ton 3speed when I press the clutch it goes soft after pumping it 6 time or so pressure builds so I can shift. What is the issue
Re: Clutch issues HELP
November 08, 2008, 09:37:25 am »
Either you have air in the system or a leak. Check the clutch master and slave for evidence of fluid leakage.
greenkeeper
November 08, 2008, 10:04:26 am »
???I don't see any signs of leaking and now there is no pressure at all. I have to put it in gear before starting engine. Then pressure builds up and I can get it to shift. The fluid looks pretty dirty in the reservoir cup. Could it be the clutch slave? Or is it possibly the pressure plates are worn out?
November 08, 2008, 10:12:21 am »
If you can't build pressure, you have no leaks then the clutch master is shot.
1976Scottsdale
November 08, 2008, 05:53:38 pm »
Time for a new clutch master cylinder. Runs $40.00 from O'reilly's. Just sold one to a guy today with an 87 V-20 with the same issue. Fixed it right up.
greenkeeper
November 09, 2008, 09:44:45 am »
It turns out the seals on the clutch master were blown out. I picked up a new one for $43. Im putting it in today. Ill keep you posted. Thanks for the input.
greenkeeper
Re: Clutch issues HELP with bleeding it
November 11, 2008, 05:56:55 pm »
I just installed the clutch master and am trying to bleed it are there any tricks to doing this or is it just pump away as you fill the reservoir
November 11, 2008, 06:58:24 pm »
Where in CT are you from?
Push the pedal down and have an assistant open then close the bleeder. Repeat until all the air is gone and keep the master full.
greenkeeper
November 12, 2008, 08:34:52 pm »
I'm in Wethersfield. I finally found the bleeder on top of the slave cylinder which also need to be replaced. After 1 hour of bleeding the system of air the clutch is working again. Better then ever.
Engine/Drivetrain
Clutch issues HELP
