Author Topic: need a good inuslator  (Read 5254 times)
Offline murraygmc
  • 85 gmc 4x4
« on: November 08, 2008, 03:01:56 pm »
what would be a good replacemint insulation under the mats and seat mine has ben soaking wet or sumthin its real nasty and fallen apart probably not doing its job
85 gmc high serria 4x4
Re: need a good inuslator
« Reply #1 on: November 08, 2008, 03:34:13 pm »
Nothing. You need to find out where the water is coming from first. Duct wrap and all that other stuff you see everyone using is great until it gets wet. It will never dry. So find out where the water/moisture is coming in from
Offline murraygmc
  • 85 gmc 4x4
« Reply #2 on: November 09, 2008, 07:15:10 am »
OK thanks ;D i should have thought of that i think the back glass got busted , when i took the seat out there was glass every where and whoever replaced it must have let it sit out side a while  plus they went the cheep route and put in a solid back glass cuz in the glove box it said it was supposed 2 have a sliding rear window  >:(
