Author Topic: Oil press. unit  (Read 3378 times)
Offline shankbonanza
  • 1980 Chevy K10 Bonanza 350/th350/np205/12bolt rear
Oil press. unit
« on: November 12, 2008, 03:24:20 pm »
     I was installin my detent cable on my 1980 chevy 1/2 ton 350/th350  and when I was installin it back on the carb I accidentally knocked off the oil pressure sending unit?  I believe and when I did this the 45degree connector (to get around distributor) cracked off in the block or manifold.  I was wondering your thoughts on pulling that out and gettin a new connector? maybe an easy out?  what are your ideas?  Thanks guys
Offline dumbucket1
  • Too Many Trucks
  • Coal Hauler
Re: Oil press. unit
« Reply #1 on: November 12, 2008, 03:49:50 pm »
Ive done this a few times. I just tapped in a screw driver in it and screwed it out.
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
Re: Oil press. unit
« Reply #2 on: November 12, 2008, 07:58:12 pm »
it is hollow, so an extractor won't have any problem gettin it out.
Also, on my 79, i don't have an angle on it to get around the distributor.  Kind of strange, unless your intake isn't stock or something.
