Interior & Equipment
sub box idea behind the bench seat
Topic: sub box idea behind the bench seat (Read 68570 times)
1983stepside
December 02, 2008, 06:36:16 pm »
hi im kinda new to this site and building a cool truck im wanting to either build or buy (rather build save money) a sub box couple problems i have are
1 im not sure what size would sound good i was thinkin 8 or 10 inch subs would be good with new speakers in the dash and some how speakers under my vents near the floor on the pass side and by the parking brake on the driver side not sure the proper name for them besides vents
any help,ideas,pics or all of the above would be great thanks
dunedigger
Re: sub box idea behind the bench seat
December 02, 2008, 06:58:46 pm »
I've been out of the stereo stuff for quite some time but I bought a set of 8" subs once and couldn't slide my seat back all the way. I took them out to build my own box and the speakers themselves with no box wouldn't let the seat slide back all the way. So, I don't have them anymore. I have always meant to get a set of flat subs that are electronic. I have heard they are very compact for what they do. I had a set of 6x9 cerwin vega's that sounded so good in a cavalier I had I couldn't believe it. I put sound mat around the cab corners and built custom boxes for them with a vent tube and all, they sound pretty bad in there. I have a set of high end boston acustics in my 80, also sounds bad. I have almost given up on making one of these truck sound good with a stereo so it will be interesting if anyone has some good advise.
1983stepside
December 02, 2008, 07:02:00 pm »
wow thanks for the advice and maybe ill tyr that just use some 6x9s do you have a pic of your box you built for them?
dunedigger
December 02, 2008, 07:05:20 pm »
No I don't have a pic of the ones I built and that truck is at the fairgrounds in storage so I can't get you one. I bought a kit somewhere a long time ago to put 6x9's in my 80. I like the one I built better, I used plexy glass and turned out very well.
dunedigger
December 02, 2008, 07:06:05 pm »
I should add if you have a custom seat instead of a bench it will open up all kinds of room for a sub
1983stepside
December 02, 2008, 07:14:13 pm »
ya i thought of bucket seats so i could build a cool center console but i wanna keep the truck lookin prety stock and how it looked since ive owned it since ive was 14 years old
December 02, 2008, 08:26:14 pm »
http://forum.73-87chevytrucks.com/smforum/index.php?topic=8901.0
bigblue09
December 03, 2008, 11:00:03 pm »
i have 2 10 inch subs behind my stock seat. the seat is almost all the way up but they sound really good. i also have to tweeters on the dash and custom 61/2 inch speakers in the doors. i really like it.
'87 Silverado EFI 305
1983stepside
December 04, 2008, 03:18:29 pm »
thanks bigblue let me some pics
bigblue09
December 04, 2008, 04:59:26 pm »
ok i will post some tomorrow because its dark here and im about to have to go to work.
SUX2BU99
December 04, 2008, 05:07:02 pm »
Check out my page for some ideas. Page 6 under my 1997 Avenger shows my old system. Under my yellow truck's own page is some pics of the new console setup I'm building to hold 1 12"
http://www.cardomain.com/id/sux2bu99
I've seen 4 8's in these trucks, and 2 10's + 2 12's all in 1 box, but the depth behind the seat usually limits a person to using 8" subs or maybe shallow 10s. There are shallow-depth 12s out there too and I've heard good things about the JL Audio 'flat' subs. They are under 3" deep and 3" is about the depth limit at the bottom that you would want to avoid moving your seat.
bigkountry
December 05, 2008, 10:42:05 am »
Check out the Memphis S-class shallow mount subs. Memphis is known for big bass in small enclosures. I have two PR10's under the rear seat of my extended cab coupled with a 1000D and it is all you would ever want.
http://www.memphiscaraudio.com/
jefferias
December 05, 2008, 05:23:58 pm »
i have a shallow pioneer 10" sub behind my stock seat. i need to have the seat all the way back otherwise i cant really drive it and i have about 1" b4 the seat touches the sub box at the top. i found a really shallow box (2nd one i had to buy grrr) at "visions electronics" that mated with the shallow sub perfectly. sounds good too with my crappy amp! i also have four 6x9's in the back with a stiffening cap. no room behind there for nothing else haha. i dont know how to upload pics here so i guess its time to use the search function lol
bigblue09
December 05, 2008, 10:52:20 pm »
i have two full size 10s. there are a few shallow 12s that you can get now. rockford, kenwood, kicker, jl all make them they are kinda expensive though.
bigblue09
December 06, 2008, 01:19:57 pm »
head unit
custom 61/2 inch door speaker
2 10inch subs behind the seat
tweeter in the dash one on each side. my amp is under the driver side part of the seat i have to take the seat out to get to the whole thing. i think its 650watts not sure on that one.
