383
4
7
Topic: 383 (Read 57920 times)
Re: 383
Reply #15 on:
December 25, 2008, 09:21:50 am »
If the engine was bored .060 over you would have 388 CID
(½ bore)² x π x stroke x # of cylinders = CID
example 4.030 bore ÷ 2 = 2.015 to the second power = 2.015 x 2.015 = 4.060225
4.060225 x 3.14 (pi) = 12.749106
12.749106 x stroke 3.75 = 47.809147
47.809147 x 8 cylinders = 382.47317
383 CID
hotrod24
Re: 383
Reply #16 on:
December 25, 2008, 02:35:01 pm »
i know it is suppost to be a 383 from a 350 but i dont know what it was bored so i am just going to tear it down and see what the shop thinks because i have no idea
1978 pontiac grand prix...
Re: 383
Reply #17 on:
December 25, 2008, 03:57:37 pm »
standard bore is 4"
typical oversizes are .030", .040", .060"
.030" = 383 with 3.75 stroke
hotrod24
Re: 383
Reply #18 on:
December 25, 2008, 04:28:45 pm »
so could i build a 396?
Last Edit: December 25, 2008, 04:36:41 pm by hotrod24
frogman68
Re: 383
Reply #19 on:
December 25, 2008, 04:38:12 pm »
Quote from: hotrod24 on December 25, 2008, 04:28:45 pm
396 is a big block 383 is a small block
hotrod24
Re: 383
Reply #20 on:
December 25, 2008, 04:47:00 pm »
thats what i thought just giving it try so how high could i go?
frogman68
Re: 383
Reply #21 on:
December 25, 2008, 04:54:33 pm »
at .060 it would be (I think) a 388
hotrod24
Re: 383
Reply #22 on:
December 25, 2008, 04:57:31 pm »
ok i will just wait and stick with the 383 and then put a big block in a 2wd drive
eventhorizon66
Re: 383
Reply #23 on:
December 25, 2008, 05:28:17 pm »
Both 3.875" and 4" stroke cranks are available for the SBC. With a 4.03" bore they would give you 395 cid and 408 cid, respectively. But, I believe, at this level, stroker-profiled cap-screw type rods and a small-base circle cam become mandatory for clearance. Also, rod/stroke ratios become quite low (for an SBC) with these strokes, which really doesn't mean much for a mild street engine other than marginally increased piston side-loading and bore wear.
Last Edit: December 25, 2008, 05:31:05 pm by eventhorizon66
'85 C10 SWB 350
700R4
TKO600
hotrod24
Re: 383
Reply #24 on:
January 09, 2009, 02:14:15 pm »
what is the differents in a 350 and 383 what parts would i need for the 383?
frogman68
Re: 383
Reply #25 on:
January 09, 2009, 02:18:55 pm »
Quote from: hotrod24 on January 09, 2009, 02:14:15 pm
350 has 4.000 piston's 383 has 4.030 pistons
350 has a 350 crank
383 has a 400 crank
Think that about covers it. Some internal work needs to be done for rod clearance too
hotrod24
Re: 383
Reply #26 on:
January 09, 2009, 02:37:52 pm »
ok i was just wanting to know because i am going to get a rebuild book and i did not know if i should get it for a 350 or a 383
Re: 383
Reply #27 on:
January 09, 2009, 02:47:46 pm »
It's the same thing. you may have to clearance grind the connecting rods and everything will be a test fit assembly. Once you have it all together you may want to rip it all apart and have everything balanced. If you're gonna build a 383 do it right or don't do it at all imo
hotrod24
Re: 383
Reply #28 on:
January 09, 2009, 03:12:29 pm »
i agree vile if you are not going to do something right the first time dont do it at all
Lt.Del
Andy aka:SgtDel
DelbridgePhotography.com
Re: 383
Reply #29 on:
January 09, 2009, 04:34:47 pm »
since a 383 stroker uses a 400 ci crank, the flywheel/flex plate will have to be for a 400 crank, and the harmonic balancer, since that goes with the crank.
www.delbridge.net/install
www.DelbridgePhotography.com
www.HikerMania.com
www.delbridge.net/suburban
4
7
383
