Author Topic: What tires should I run?  (Read 7414 times)
Offline grinder1989
« on: December 22, 2008, 10:48:56 pm »
My truck is going to be street strip.  I have a nice set of rims and tires, but I need some big sticky tires that I can deal with everyday.  I don't want drag radials because I occasionally have to drive in the rain.  I have 15x10 BFgoodrich radial T/A's but I want something a bit more sticky for the rear.  Suggestions?
Sundown Authorized Dealer, Akron OH
Re: What tires should I run?
« Reply #1 on: December 23, 2008, 07:12:26 am »
Drag radials sound exactly like what you want but you don't want them.
I've used hoosier (would not recommend), BFG, and Mickey Thompson. The M/T's handle the best in wet weather and as long as you aren't driving like a tard lick you'll be fine.
Offline grinder1989
« Reply #2 on: December 23, 2008, 08:41:48 am »
I mean I could deal with them I suppose, I just know they're bad in the rain.  How much do the M/T's cost?  Roughly that is.  Like $600 for a set?
« Last Edit: December 24, 2008, 09:48:09 pm by grinder1989 »
« Reply #3 on: December 24, 2008, 10:52:30 am »
Drag radials are your best bet.  If you take it easy in the rain you should be fine.
Offline fitz
« Reply #4 on: December 28, 2008, 08:31:33 pm »
I run Mickey Thompson Street ET's on my Camaro at the track. They took 4 tenths off in the 1/4 mile compared to the B.F. Goodrich radial t/a's I had on the car.  I usually don't drive with them on the street but they are DOT approved.
Offline HAULIN IT
« Reply #5 on: December 29, 2008, 12:37:33 am »
Grinder, I'm running 325/50-15 ET Street Radials (28"x11") on a 10" wheel. They have worked real well for me. I have gotten caught in the rain a couple times...like the others have said, you have to drive like your concerned, but no problems. The regular ET Streets are NOT near as friendly in the rain. Lorne
Offline oldwhity
« Reply #6 on: December 29, 2008, 06:24:42 am »
I used to run M&H Racemasters Drag Radials on a daily driver. I broke 3 sets of ring gears with them dumpin the clutch at 4000-4500 rpm so they do hook up. But like the others have said, they're not great in the rain.
« Last Edit: January 02, 2009, 11:32:16 am by oldwhity »
Rob G.
81 Chevy K20 4x4 LWB stepside
Offline grinder1989
« Reply #7 on: January 11, 2009, 11:05:29 pm »
I found a sweet deal on some older MT cheater slicks.  $100 for the pair and they are in great shape.  I will eventually move up to a nicer tire but these will work for now.
