Author Topic: Transmission Pan leak  (Read 7270 times)
Offline chatttown423
« on: December 26, 2008, 12:16:26 pm »
I have a 1984 c10, with a 350 and a THM700-R4. I have replaced the transmission filter and pan gasket, i replaced it with a rubber gasket. Now when i crank the truck and turn it off the tranny fluid spills out of the corner of the pan. I have tightened the bolts to 10ftlbs, and the pan still leaks from that same corner. What should i do? Should i try a cork gasket?
thanks,
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
Re: Transmission Pan leak
« Reply #1 on: December 26, 2008, 04:42:27 pm »
you sure it isn't the fill tube o ring?  It may appear it comes from the pan, but without extensive study, it may come from above...perhaps tranny lines?
Or, if it is definately the pan, it could be warped.
Offline TexasRed
« Reply #2 on: December 26, 2008, 05:53:54 pm »
maybe the gasket didn't seat properly? Or maybe some gasket material from the old gasket is still on the pan or transmission? If it turns out to be a warped pan, there's some aluminum one on fleabay.
« Reply #3 on: December 26, 2008, 09:15:17 pm »
I found the leak it was one of the cooler lines that was loose.
But the transmission has lost 2nd gear. While driving, it will leave 1st and will not go to 2nd it will just rev high and wont switch gears.
Will i need a new transmission? Or is there be a simple fix?
thanks,
Offline TexasRed
« Reply #4 on: December 26, 2008, 09:23:55 pm »
Maybe the new filter isn't in there right?
« Reply #5 on: December 26, 2008, 09:34:59 pm »
that could cause the transmission to lose 2nd gear?
« Reply #6 on: December 26, 2008, 10:02:34 pm »
Could it be the governor?
Offline Unofficial
« Reply #7 on: December 26, 2008, 10:09:34 pm »
That happened to me after I changed my fluid in my 700R4. It turned out that one of the pistons in the valve body seized up.
1987 Custom Deluxe R10
350 TBI bored .040 over
MSD ignition
« Reply #8 on: December 26, 2008, 10:14:03 pm »
Did you get it fixed? If so,how much did it cost you?
and what parts did you have to buy?
« Reply #9 on: December 27, 2008, 12:16:22 am »
Make sure the TV cable is adjusted correctly. If it's slipping into 2nd odds are the band isn't applying and you can check the servo assembly without pulling the trans. If the band was bruned you would have found a lot of greyish cocky in the pan.
« Reply #10 on: December 27, 2008, 08:16:13 am »
When i took the pan out there was a lot of thick grey stuff at the bottom of the pan, so if this means the band is burned, do i need a new transmission? or can it be fixed?
thanks,
