Author Topic: starter kept going today  (Read 7366 times)
Offline dumbucket1
  • Too Many Trucks
  • Coal Hauler
« on: December 26, 2008, 01:22:12 pm »
When I started my 76 with a 350 today I heard the starter keep turning so I immediately shut the truck off only for the starter to keep turning. Then I turned the key back on and it started back up so I turned the key back off and the starter yet still kept turning.
I hurried up and popped the hood and removed the positive cable from the battery which was very hot by the way. (good thing I was at home and the truck was in the garage).
Ok so I looked at all the wires on the starter and nothing is touching and the wires look good. I cycle the key in the column and it seems to be functioning normally.
So here is the question. Could the starter just be worn out and caused this? I would say the starter is a good 5 years old but it didnt have any weird symptoms. I'm in no big hurry to fix this as I have other vehicles but I hate to know what might have happened if I were not at home and this happened.
Offline dumbucket1
  • Too Many Trucks
  • Coal Hauler
Re: starter kept going today
« Reply #1 on: December 26, 2008, 01:33:52 pm »
also if I try to put the posiive cable back on the battery a big spark jumps
Offline frogman68
« Reply #2 on: December 26, 2008, 03:18:07 pm »
Sounds like the solenoid is hung open "tap" it with a hammer
Offline dumbucket1
  • Too Many Trucks
  • Coal Hauler
« Reply #3 on: December 26, 2008, 04:25:21 pm »
that worked but now it sounds like the starter is catching on the flywheel while running which it has never done before so I guess I will just replace it to be on the safe side.
« Reply #4 on: December 26, 2008, 04:28:19 pm »
you probably need a new starter. I went through this on a friends 94 Blazer. We went through 3 starters (reman) and he finally bought a new one, and problem went away.
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
« Reply #5 on: December 26, 2008, 04:41:17 pm »
Sometimes the cause of the sticking solenoid switch is a very low charge.   Throw a good juicy charge on the that joker and you should be good to go.  Now, why the battery power declined is another story.  Alternator? Old battery? connections?
that happened to me when I knew the battery was low (left lights or something on) the went to start it, the starter kept on chugging, no matter the key position.
« Reply #6 on: December 27, 2008, 12:21:16 am »
You should pull the negative. The starter solenoid is sticking. Just replace the starter.
Offline Igosplut
« Reply #7 on: December 29, 2008, 05:25:49 pm »
He's right. a bad or shorted battery can do that.
Offline dumbucket1
  • Too Many Trucks
  • Coal Hauler
« Reply #8 on: December 30, 2008, 02:37:18 pm »
I took the starter apart and it ended up being the bendix had a broken arm.
Offline lowbucktruck
  • Old Reliable
« Reply #9 on: December 30, 2008, 03:17:06 pm »
Yup, sounds like a bad starter.  Napa stocks replacement starters for our trucks.  I had to replace mine in my '73 a few years ago, now she starts up on the first crank. (of course, a new battery helped!)
