Author Topic: switching from a standard shift indicator to an overdrive indicator  (Read 8240 times)
Offline bigjayfromwa
       Hopefully you can help me out...  I have a 76 chev 3/4ton 4x4 and i am looking at swapping out the th350 tranny for a th700r4 tranny to get the overdrive option.
My problem is i would like to keep the column shifter instead of going to a floor shifter.  Do you know of anybody that makes as shift indicator that i can use?  since i only have P R N D 2 1 on my dial?  or if there is any other chevy model i can buy to get the overdrive dial?? (without too much modification)
I really dont want to have to modify the interior like that, i would rather leave the stock appearance.
Thank you very much for any information you may have!!!
Jason
Offline Prong
Re: switching from a standard shift indicator to an overdrive indicator
« Reply #1 on: January 02, 2009, 12:15:36 am »
Swap the indicator (2 screws on the cluster and one on the column shift tube for the indicator wire) and you're good to go. New ones are about $35 IIRC.
79 K10 SB 4x4 383/Th350
79 K10 LB 4x4 350/SM465
« Reply #2 on: January 02, 2009, 08:13:11 am »
Any truck that came with a 700R4 will have one.
Offline oldwhity
« Reply #3 on: January 02, 2009, 10:48:00 am »
Junkyard time!
Rob G.
81 Chevy K20 4x4 LWB stepside
« Reply #4 on: January 02, 2009, 06:31:45 pm »
Jason,
I sent you an email on this, did you get it or did you post here first?
« Reply #5 on: January 02, 2009, 09:14:50 pm »
Thanks for the info.... I posted on her first before i got your email...
thank you though
Offline joesgarage71
  • Wrench
« Reply #6 on: January 08, 2009, 12:53:52 pm »
 There is a shift plate inside the column you need to modify too.
