Author Topic: 700R4 TO A TH350  (Read 10523 times)
Offline 85BURBAN
700R4 TO A TH350
« on: January 03, 2009, 04:01:15 pm »
recently bought an 85 jimmy with a 305,700r4 combo have a suburban with a built 350 and a th350 the motor is definately going in the 700r4 is slipping and the th350 shifted great od would be nice but the cost of a rebuild is something i can dish out right now, would the th350 dolt right up and what kind of modification wouls i have to do to go from the 700r4 to the th350 any input would be much appreciated
Re: 700R4 TO A TH350
« Reply #1 on: January 03, 2009, 04:08:48 pm »
Is that a typo or do you not have the money for a rebuild?  ??? If you have the $ to rebuild the 700R4 go that route. You'll appreciate overdrive.
Offline 85MudMonster
« Reply #2 on: January 03, 2009, 04:53:32 pm »
I think he is saying he does not have money to rebuild the 700r4 right now. If he wants to sell it I'm interested.
Dan
85 Chevy K10 - 408 BBC from a 71 Chevelle SS, TH350, NP208, 33" Mastercraft Courser M/T
Offline 85BURBAN
« Reply #3 on: January 03, 2009, 05:04:59 pm »
sorry about the typos but yes right now a rebuild isnt in the budget and i do not want to sell i will rebuild eventually but if it goes would the th350 bolt right in?
« Reply #4 on: January 03, 2009, 05:13:59 pm »
I think there is a difference between th 700r4 and the th350, but i'm pretty sure that the th350 and the th400 are the same. Vile, is there a difference in the mounting points of the 700r4 and the th350?
Dan
Offline TexasRed
« Reply #5 on: January 03, 2009, 05:15:25 pm »
The mounting would be a little different on the th350. There's a chance the th350 has long tailshaft and wouldn't require a driveshaft mod. In the end, it might be cheaper to just rebuild the 700r4 on your own then to move the th350 in it.
« Reply #6 on: January 03, 2009, 06:02:15 pm »
85MudMonster do you need a trans?
You will need an adapter to your transfer case
Offline 85BURBAN
« Reply #7 on: January 03, 2009, 06:20:30 pm »
vile
   the driveshaft should be reusable right ive just seen the adapter kit on line it comes with a new dipstick tube, detent cable and such.hopefully i can swap out hte trannys soon(weather permitting) and have the 700r4 rebuilt over the summer so ican can give the 350 in my burban a little refreshing and install both hopefully by august.
« Reply #8 on: January 03, 2009, 06:28:48 pm »
Bring the 700R4 to me. I'll rebuild it. I'm close enough
« Reply #9 on: January 03, 2009, 06:32:44 pm »
My truck needs many things, I need a new transfer case so I can actually put it into 4WD. I'd like to have a 700r4 so that I can have overdrive for the interstate. I'd like to put a manual in it but I ain't got that kind of time (patience) or money
Dan
« Reply #10 on: January 03, 2009, 06:34:02 pm »
find a cheap 4wd parts truck
Offline 85BURBAN
« Reply #11 on: January 03, 2009, 06:58:19 pm »
when im ready to rebuild i just may do that,you seem like you know your stuff how far into ct are you from ri?
« Reply #12 on: January 03, 2009, 07:01:27 pm »
Click Coventry CT
Offline dumbucket1
  • Too Many Trucks
  • Coal Hauler
« Reply #13 on: January 03, 2009, 07:28:07 pm »
so I take the suburban is 4wd also?
Offline 85BURBAN
« Reply #14 on: January 04, 2009, 10:26:03 am »
yes the burban is a 350 with a th350 and a np208 transfercase its actually a 85 body on a 79 chassis
