Author Topic: I need help with custom seat mounts.  (Read 22637 times)
Offline team39763
« on: January 13, 2009, 02:16:50 pm »
I have a racing seat I want to mount, but I don't want to use the bucket seat sliders that I had.  They didn't fit in the first place, and would've let me eat the steering wheel in a front impact.  Not only that, but it's easier for me to just make these L shaped brackets since I'm not much of a fabricator.
Here's a drawing of my plan.  The bracket will be bolted and welded at the yellow points near where the stock brackets bolted in.  Then the seat will be bolted down to the bracket with good hardware.  The bracket itself will be 1/8" steel(or do I need thicker?).
http://i46.photobucket.com/albums/f143/team39763/SEATBRACKET3.jpg
Will this work?
« Last Edit: January 13, 2009, 02:30:34 pm by team39763 »
Offline ont_guy_38
Re: I need help with custom seat mounts.
« Reply #1 on: January 13, 2009, 02:41:18 pm »
I think you will find the seat will sit up way too high if you make your brackets like that
Offline team39763
« Reply #2 on: January 13, 2009, 02:59:50 pm »
I just went and checked on that and it should be ok.  The seat is very low and should be perfect.  Other than that, do you see any reason not to build it like that?  Will 1/8" steel be thick enough?  I need to be able to bend it for that 90* angle.
Offline ont_guy_38
« Reply #3 on: January 15, 2009, 02:15:17 pm »
If they are ok height wise then yes that should work fine,I think you might have to add some kind of an extra support halfway in between though
« Reply #4 on: January 15, 2009, 03:30:26 pm »
Personally I would lay out some 3/16" flat and bend it over like the outer side and mount it.
Offline HAULIN IT
« Reply #5 on: January 15, 2009, 05:30:13 pm »
Are you planning to use 1/8" angle or flat stock?
« Reply #6 on: January 15, 2009, 05:32:14 pm »
Offline team39763
« Reply #7 on: January 16, 2009, 08:38:09 am »
I was planning to use 1/8" flat stock.  Should I be using angle?
I'll look and see if they have 3/16 at the store, that might work out better...I'll check.
That makes sense.
You can buy seat mounts already made to fit our trucks.
http://store.summitracing.com/egnsearch.asp?N=700+400063+306563+4294908216+4294908213+115+4294925074&autoview=sku
I wish I would have seen those a few months ago when I wasted my money on these stock bucket brackets(which still didn't fit) from the junkyard.  I don't have the money for those now.
« Reply #8 on: January 16, 2009, 09:37:22 am »
You have Stock bucket brackets from a 73-87?  The required an inner mount and Jeff has a template on his site for them.
Offline team39763
« Reply #9 on: January 16, 2009, 12:37:39 pm »
Yeah, I got them off a 80something model, but I didn't understand why they didn't fit in the truck.  I thought I had everything.  Which guy is Jeff?
« Reply #10 on: January 16, 2009, 01:05:46 pm »
Team-  I sent you a PM
« Reply #11 on: January 16, 2009, 05:45:42 pm »
Jeff = bigblock73
http://73-87.com//7387garage/interior/factory_buckets.htm
There is a template you can print out on that page, but there is a "hump" in the center floor for the seat to mount.
Offline team39763
« Reply #12 on: January 16, 2009, 06:47:17 pm »
It's almost done.  I used a combination of angle and flat stock.   But my goodness it added some weight.  I guess I'll just have to shave some weight somewhere else...probably gonna install a newer model aluminum radiator with the plastic tanks.  Thanks for the help guys.
Offline 85MudMonster
« Reply #13 on: January 16, 2009, 08:41:33 pm »
How do these work, are they adjustable? I'd like to get some old school low back bucket seats for this truck but I know that I would need new brackets for that, and want the seats to be able to slide back and forth at least a little bit....
Dan
85 Chevy K10 - 408 BBC from a 71 Chevelle SS, TH350, NP208, 33" Mastercraft Courser M/T
Offline Stantonss
« Reply #14 on: April 07, 2009, 10:55:42 am »
[/b]
Good question... Anyone know for sure?
