Author Topic: My "never ending" project  (Read 16547 times)
Offline DRIVINFST
« on: January 15, 2009, 01:07:32 pm »
Thought I would share my project I've been working on for years.  First I had no place to work on it, now no $$$.  It's a 1979 GMC K15 High Sierra that has been in my family since it was new.  In 2001 I converted it to TBI.  Now I doing a full resto with the TBI, 700r4, NP 203, 4 inch lift and 33's.  I'm also converting to 3/4 ton running gear.  Anyone with any advise on this conversion, please chime in.  One question I have is I got the 3/4 ton master cylinder, do I use the 3/4 ton or 1/2 ton proportioning valve?
When I finally got it from my dad in 2000
The TBI swap
Under construction
Offline murraygmc
  • 85 gmc 4x4
Re: My "never ending" project
« Reply #1 on: January 15, 2009, 01:17:48 pm »
i like it man
85 gmc high serria 4x4
Offline hotrod24
« Reply #2 on: January 15, 2009, 01:23:50 pm »
very nice
1978 pontiac grand prix...
« Reply #3 on: January 15, 2009, 02:01:18 pm »
nice!
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
« Reply #4 on: January 15, 2009, 05:42:35 pm »
Looks good!  good progress!
In the top engine pic, whats that ribbed canister with two hoses going to it, on the right fenderwell?
Offline DRIVINFST
« Reply #5 on: January 15, 2009, 06:34:17 pm »
It's an old oil cooler and filter that uses toilet paper as a filter media.  I don't put paper in it anymore, but I left it after the TBI swap because its such a conversational piece.  People always ask about it, either they say "I haven't seen one of those in years" or "what the heck is that?".  I think of it as a good luck charm considering the original drivetrain from the motor to the axles went about 330,000 miles.
Offline oldwhity
« Reply #6 on: January 15, 2009, 06:54:02 pm »
Welcome from Maryland. That's a good looking project.
Rob G.
81 Chevy K20 4x4 LWB stepside
Offline DRIVINFST
« Reply #7 on: October 22, 2012, 08:23:52 pm »
Reviving an old thread.  After a 4 year hiatus, finally back to work.  Cleaning up the chassis and painting it, 4" Tuff Country lift, and some frame repair after a minor fender bender that took out the front frame horns.  Also need to remove and repair the frame to steering box location.  Will now be getting a 5.3 LS with 4L60E and a 231C T-case.
Offline oldwhity
« Reply #8 on: October 23, 2012, 07:11:26 am »
I see progress!  Great job!
Rob G.
Offline sphinx
« Reply #9 on: October 30, 2012, 09:14:38 pm »
Looks good.  What did you paint your frame with?
I'm working on my 1976 C10 and need to paint the frame while I have the front tore down.
Offline DRIVINFST
« Reply #10 on: November 01, 2012, 08:05:55 pm »
Thanks.  I used Summit Racing's epoxy semi-gloss black chassis paint.
http://www.summitracing.com/parts/sum-csumup501
Offline mikek20
« Reply #11 on: November 03, 2012, 08:27:19 pm »
The black chassis paint is great!,  Your project is coming along awesome       : also might i suggest for others looking to do frame work, POR-15, and chassis saver paints from Magnetic paints. Good paint stores carry their own versions often but they are all pretty good. I know most you can paint directly over rust and it actually seals it from further rust if applied properly.
Offline DRIVINFST
« Reply #12 on: May 10, 2014, 12:32:05 pm »
Fixed the frame, test fitted the sheet metal, painted the front half of the frame, ditched the old worn leaky 3/4 ton axles for 1/2 ton axles (the front is a brand new GM crate axle a guy had in storage for 20 years, never even been installed, and the rear is a 6-lug semi-float 14 bolt) and received my GM crate engine.  All aluminum LC9 E-rod motor.  Finally a little progress to show!
Offline jaredts
« Reply #13 on: May 10, 2014, 06:11:26 pm »
Great job!  I love the mini spray booth you built around the front end.
« Reply #14 on: May 10, 2014, 06:12:37 pm »
     Nice job.
