The Highs (Raising/Lifts)
suspension lift kit for 2wd
Topic: suspension lift kit for 2wd (Read 15537 times)
gold84gmc
January 21, 2009, 09:27:02 pm »
can you get a suspension lift kit for a 2wd truck or can u only get a body lift
92 buick century custom 3.3L
dunedigger
Re: suspension lift kit for 2wd
January 21, 2009, 09:29:52 pm »
There was a guy here in town with a direct application 4" lift for his truck. I don't know where he got it or if you can still get it though. I didn't really like the looks of the coil spring angles on it.
choptop
Extended cab fanatic
January 21, 2009, 09:32:49 pm »
Fabtech makes one. I think Capt found the link to it one time. I have a 2 or 3 inch a-arm kit.
January 22, 2009, 12:59:48 pm »
JC whitney used to sell one. Not sure if they still do.
⌠ŻŻŻŻŻ' [☼===☼]
frogman68
January 22, 2009, 01:08:11 pm »
http://www.truckaddons.com/Catalog/subpages/fabtech_chevy_2wd_5.htm
gold84gmc
January 22, 2009, 02:11:43 pm »
my truck is a 3/4ton so it has 8 lugs...that kit says its for 5 lug....and do you know of any cheaper kits?
January 22, 2009, 02:55:36 pm »
There isn't anything for a 3/4T truck as far are a "lift" kit. I doubt you could find anything cheaper than $550 for any kit though.
You could use taller springs in the front, or contact AIM Industries and see if they would make you a lift spindle. They used to make them for 1/2T trucks.
choptop
January 22, 2009, 03:05:33 pm »
My original plans for these were for a 3/4 ton. The main difference is the upper ball joints. I was going to put on a 3/4 ton. I was going to machine the sockets to accept the 3/4 ton ball joints and beef up the area to re-enforce the area. Should work, but will take some machine work
82TARDIS
PB Blaster Addict
January 31, 2009, 04:35:31 am »
Gold84...I got 2.5" lift in the front by installing C30 HD Coils. I bought them at Advance Auto Parts for around $100. I had to replace the springs anyway, since my left was sagging pretty badly. They go in pretty easily...no need for spring compressors, etc...it's definitely a two man job though.
I lifted the rear 2" with some crappy blocks for the time being, later on I'm planning on putting in the corresponding C30 HD leafs if I can find them.
The truck still sits about .5" higher in the rear than in the front, but thats how I like it.
BTW, you'll have to replace your shocks with "lift kit" type shocks. My truck is VERY tight and still a little bouncy, but rides much better than it did with the sag...
The whole project (minus the shocks) set me back $130 or so...
January 31, 2009, 11:32:43 am »
1Ton springs will definitely lift it up some. 123pugsy did this on his (by accident I believe)
78 Chevyrado
Z62 ON-ROAD
Site Supporters
January 31, 2009, 05:01:10 pm »
I got about 2inches of lift on mine. Here's my thread about it, look about half way down the page.
http://forum.73-87chevytrucks.com/smforum/index.php?topic=9090.0
