Author Topic: Rebuild project questions  (Read 5837 times)
Offline greenkeeper
« on: February 01, 2009, 01:09:25 pm »
I am just starting my teardown and rebuild of my 87 R-30 Dump truck.  The body has been repaired extensively over the years from snow plowing. the frame is in good shape and the engine only has 10k miles on it.  I am wondering if its worth repairing the body or should I look to just replace the cab with a newer used one. The current condition of the body is very worn. any thoughts? :-\ Steve
Re: Rebuild project questions
« Reply #1 on: February 01, 2009, 07:38:40 pm »
Steve, do you have any pix? Where in CT are you from?
« Reply #2 on: February 02, 2009, 01:46:25 pm »
What are we looking at?  Pics would help.
Offline greenkeeper
« Reply #3 on: February 22, 2009, 10:15:36 am »
I am in wethersfield, CT Vile and I should have some pictures up soon.
Offline 82gmc3/4ton
« Reply #4 on: February 22, 2009, 12:12:00 pm »
I came across the same problem. It had the rockers and corners replaced and also had slip on rockers  over the replaced one. I ended up getting another cab. It still needed some work but a heck of a lot less then my old cab. Plus it came with extra parts I was able to use and or sell to keep my project going. Make sure you check all the trouble spots, the tranny hump, and get the best one for the money.
« Reply #5 on: February 22, 2009, 12:23:40 pm »
you're not too far from me. I would say if it needs cab corners and rockers, maybe some floor patching keep the cab but if the support structure is gone maybe a new cab would be a better option. Post pix when you can.
