Author Topic: big block weight compared to small block  (Read 6999 times)
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
« on: February 10, 2009, 07:41:52 pm »
How much more does a bigblock setup weigh than a comparable small block, i.e. with the same accesories and stuff?
Re: big block weight compared to small block
« Reply #1 on: February 10, 2009, 07:53:23 pm »
It's around a hundred pounds more.
Offline eventhorizon66
« Reply #2 on: February 10, 2009, 09:46:27 pm »
Is that all?  All this time, I thought it was more like 200 lbs.  So if you had an aluminum-headed BB, it would weigh roughly what an all-iron SB weighs?
'85 C10 SWB 350 700R4 TKO600
Offline 80stepsideguy
« Reply #3 on: February 11, 2009, 02:38:26 am »
Just about the same yes.
thanks
pat
1998 Chevy 1500 S/B 2wd
Offline ccz145a
« Reply #4 on: February 11, 2009, 08:31:50 am »
I always thought it was more like 200lbs more with iron heads.
« Reply #5 on: February 11, 2009, 10:44:49 am »
I think it is 120lbs.  Aluminum heads make it very close to the SBC weight.
  • Z62 ON-ROAD
« Reply #6 on: February 11, 2009, 10:47:49 am »
Thanks guys!  Even if it's 200 that's not bad.   I'm just kinda throwing around the idea of swapping to a big block when the time comes.
Another question, what do you think it costs to get all the accessory brackets, etc for a big block.  and  does a big block use the same mounts a small block does?  I'd likely be getting everything out of the junkyard, so if it's not too hard to find I'd like to get a serpentine setup since I have to buy it all anyway....
« Reply #7 on: February 11, 2009, 11:19:08 am »
The BBC will use the same frame mounts if that is what you are talking about.  As for brackets, http://www.alangrovecomponents.com/ should have some if you can't find them in the salvage yard.
« Reply #8 on: February 11, 2009, 12:04:57 pm »
Also for accessories, check these out.  It's a good idea if you want a factory-style serpentine setup, but don't want to go fishin' for the BB serpentine setup.
  • Z62 ON-ROAD
« Reply #9 on: February 11, 2009, 01:28:26 pm »
That looks like the way to go right there!
