Author Topic: Fuel Injectors and Trouble codes  (Read 9558 times)
Offline JBerryhill
  • 1987 GMC Sierra Classic SWB
« on: February 13, 2009, 04:15:18 pm »
I have an 87 GMC with a 350 ci TBI engine. My question is will stopped up injectors cause a trouble code. I have run an SES light test and nothing comes up, just the usual 12 start up code. My truck doesn't run rough but it just doesn't feel like it has the power it should and at highway speeds it seems to shudder a bit but picks up and runs fine when kicked down in passing gear. I haven't owned it very long and it has been this way since the day I bought it. The spray pattern from what I can see looks ok but I really couldn't see it that well. Any suggestions? Thanks for any help/advice......Jerry
Re: Fuel Injectors and Trouble codes
« Reply #1 on: February 13, 2009, 04:44:51 pm »
What do you have for a final drive gear ratio? What transmission do you have? It sounds like a loose TV cable 700R4 in front of a 3.08 rear end.
Offline JBerryhill
« Reply #2 on: February 13, 2009, 07:17:10 pm »
700R4 with a 3:08, do I need to adjust the TV cable? I'm thinking of switching to 3:42 gears....would that help things?
« Reply #3 on: February 13, 2009, 07:25:38 pm »
Yes, tighten up the TV cable a few clicks and see what happens.
Offline JBerryhill
« Reply #4 on: February 13, 2009, 07:36:37 pm »
Thanks for the quick and informative reply, this has been the only thing that has really bugged me about this truck, with only 53,000 on it I figure I can get a few years out of it and then pass it down to my son...........the real reason I bought it. Thanks again, Jerry
Offline DnStClr
« Reply #5 on: February 14, 2009, 10:52:21 am »
As long as you see a spray the injectors are working. I'm having a similar problem, and I think my spray is a bit heavy but mine keeps blowing the ecmB fuse and throws a code 42. At least you're not blowing fuses huh?
Don
87 Chevy Silverado
« Reply #6 on: February 14, 2009, 11:22:48 am »
Don, I think he's just feeling the lack of power due to the converter locking prematurely and not unlocking soon enough.
You are still blowing your ECM fuse? I thought you fixed it?
Offline JBerryhill
« Reply #7 on: February 14, 2009, 01:20:22 pm »
Well I found the problem, it was actually multiple things, 1 plug wire was arcing against the manifold shield (new wire set) and the fuel filter was VERY hard to blow through (new filter) these two things made a huge difference......after a few test drives I adjusted the cable back about 1/8 inch and it made it a totally different truck!!!! I still plan on the 3:42 gear set for pulling my newly used pop-up camper (another money pit) once again THANK YOU for all the help and advice, I'm fairly new to these trucks but if anyone needs any info help on Fox body Mustangs I can help in that area.   ;D    Jerry
Offline DnStClr
« Reply #8 on: February 21, 2009, 11:26:58 am »
Nice fix Jerry. Hey, keep us informed on the dif. change. I'm going down that same road soon.
Vile- the blown ecmB fuse has returned. Still sporatic. To make a long story short, troubleshooting hasn't pinned anything down yet. I'm going by the emissions manual. I've had to put everything off for a week of computer training. and back problems. ow.
Don
87 Chevy Silverado
Offline JBerryhill
« Reply #9 on: February 21, 2009, 12:30:40 pm »
I found an entire rear end with a posi unit and 3:42 gears here locally in Jonesboro, AR at a salvage yard. I got the rear end and heavy duty leaf springs and a tranny cooler from a newer truck for 200.00 I am in the process of blasting the crud off and installing new wheel cylinders, drums and brake shoes. I am waiting on some POR-15 to coat everything with and we'll see how it goes on the install. My buddy has this same unit in his truck and he said it made a night and day difference in the drivability of his truck.
« Reply #10 on: February 22, 2009, 09:11:33 am »
You will love the 3.42's!
« Reply #11 on: February 22, 2009, 10:29:46 am »
Good score!
Don, post in your other thread if you still need help.
