Author Topic: Rear differential cover  (Read 16358 times)
Offline Redneckchevy
    • Photo Bucket
« on: February 13, 2009, 08:04:23 pm »
Any one know what the torque specs are for a chevrolet 10 bolt rear differential cover?
And how well do the chrome covers last? and are they worth it?
Offline 4x4orbust
Re: Rear differential cover
« Reply #1 on: February 13, 2009, 08:21:37 pm »
not sure on the torque specs,   but i just got done taking all the schrome stuff on my 82 off.   (transmission pan, valve covers, rear diff cover)  and every one of them had rusted badly, had pin holes everywhere, and leaked.   depending on what you get, it could be better than what i had,   but i will never put another chrome thing on my truck, unless it's something that came factory.
Offline fitz
« Reply #2 on: February 13, 2009, 08:46:49 pm »
 I've never seen chrome ones that didn't rust. Aluminum is the way to go. A easy way to dress up the stock steel cover is to scuff it down, shoot it with undercoating, then install it with stainless bolts.
« Reply #3 on: February 14, 2009, 12:44:55 am »
The one grunt method, tighten them to one grunt.
Offline joesgarage71
  • Wrench
« Reply #4 on: February 14, 2009, 06:55:54 am »
This is a good method, I use it. If install anything chrome that gets near oil I always grind/sand the chrome from the gasket surface, insuring that that there is a good seal. See if I don't do this it always leaks!
« Reply #5 on: February 14, 2009, 07:42:25 am »
23 lb-ft on the bolts. I use the chrome ones on some trucks but if it's going to see a lot of wintery type weather they will rust. I don't think you have to worry about one of these rusting
    • Photo Bucket
« Reply #6 on: February 14, 2009, 08:50:56 am »
that is cool.......and i think the valve covers would be even better
« Reply #7 on: February 14, 2009, 09:45:23 am »
I had clear top valve covers on my 84 K5. They were made by a company called crossfire and Jegs sold them. Don't know whatever happened to them though, they were awesome.
« Reply #9 on: February 14, 2009, 11:35:33 am »
Those are them! Those are totally awesome!
Offline campcrf
  • stroked
« Reply #10 on: February 24, 2009, 10:22:05 pm »
wow... i gotta look for a set of them
