Author Topic: Starter Problem  (Read 8209 times)
Offline 2002on22s
Starter Problem
« on: February 16, 2009, 09:06:53 am »
Here's what I'm up against & could use you're help please. My brother has a 78 Chevy & last night installed a new starter, well he called & said that when he put the negative cable back on the battery it sparked & the starter went off......? I'm going over there tonight to help him out w/ it but right now I'm just grabbing at straws........Any ideas..?
Re: Starter Problem
« Reply #1 on: February 16, 2009, 10:23:23 am »
He probably incorrectly installed the B+ cable and it's touching ground. also make sure he hooked the small wire to the S terminal.
Offline 2002on22s
Re: Starter Problem
« Reply #2 on: February 16, 2009, 11:55:01 am »
He just called & said that he didn't mark anything when he took the old starter off - He said there are 3 threaded rods/bolts on there & one is small. One of the bigger "bolts" has what looks like a "I" on there, I'm assuming that is the negative....?
My guess is that he's crossed some wires somewhere, but ti's been a while since I had to mess w/ a starter. Thanks for the help.
Re: Starter Problem
« Reply #3 on: February 16, 2009, 02:50:14 pm »
There is no negative on the starter. the housing is negative. Your B+ cable, and fusible links attach to the B+ terminal. The small wire goes to the S terminal. The R terminal you will not use unless you have points
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
Re: Starter Problem
« Reply #4 on: February 17, 2009, 08:59:01 am »
if the negative cable is all the way down there at the starter, you have a big problem.  that puppy is usually either attached to the alt bracket for grounding or intake bolt for grounding.
Anyway, it is most likely the postive wire.  it can be black or red if the truck is old.  Always take the cable off the batter BEFORE working with the starter.   Then, no spark.
Offline 2002on22s
Re: Starter Problem
« Reply #5 on: February 17, 2009, 09:30:14 am »
He had it taken back apart & off the truck when I got there - So I'm not sure exactly what he had done, but I got him taken care of. Thanks guys
Offline frogman68
Re: Starter Problem
« Reply #6 on: February 17, 2009, 09:51:52 am »
Never had any cables when I was baking a cake  ;D
Offline oldwhity
Re: Starter Problem
« Reply #7 on: February 17, 2009, 10:07:20 am »
You beat me to it Frog! lmao :D
Rob G.
81 Chevy K20 4x4 LWB stepside
Offline Lt.Del
  • Andy aka:SgtDel
    • www.delbridge.net
Re: Starter Problem
« Reply #8 on: February 17, 2009, 01:04:52 pm »
 ;D  Nice one...look closely, I'm flipping you off  :D
Offline frogman68
Re: Starter Problem
« Reply #9 on: February 17, 2009, 01:21:25 pm »
Hey I wasnt being mean ..
If I was I would of said doughnuts not cake
LOL
Offline oldwhity
Re: Starter Problem
« Reply #10 on: February 17, 2009, 01:40:06 pm »
That's classic. :D
Rob G.
Offline Lt.Del
  • Andy aka:SgtDel
    • www.delbridge.net
Re: Starter Problem
« Reply #11 on: February 17, 2009, 09:45:41 pm »
It just gets better, doesn't it?   ;D
Offline 406 Q-ship
Re: Starter Problem
« Reply #12 on: February 18, 2009, 02:02:15 am »
Or when your brother attached the positive cable he positioned it so that it in contact with the s terminal of the solenoid.
The difference between genius and stupidity.......Genius has limits.
