Author Topic: P.S Floor is in (sorta)  (Read 7245 times)
Offline frogman68
« on: February 16, 2009, 02:25:34 pm »
Well what seems like an eternity I have the passenger floor almost done it is in and tacked just alot of welding left. I want to say Thank You to everyone here without your help I would of never got this far. Now that its done (almost) I think the driver side should go alot faster.
Had to replace the cab support the original was cracked at the support to the foot panel
Here is the rear cab support
Forgot to take a pic of the rear floor screwed down put here it is tacked in
Here is the front screwed down I think it took longer to screw it down then weld it in. I opted to cut a hole in the floor I will make a plate for were the body mount bolt goes
Front Tacked
And the front grinded
The inner rocker came up higher than the outer rocker so I trimmed it down (used the old weatherstripping as a guide)
Going back from the B pillar there is a gap that the floor doesnt cover. I think I am just going to run a flat piece from the B pillar to the rear part of the floor
I got alot of welding left but my old bones have had enough for this weekend
Re: P.S Floor is in (sorta)
« Reply #1 on: February 16, 2009, 02:30:23 pm »
Looks good!  Nice progress.   I spend Saturday afternoon hacking a 73 K5 floor apart.  I wast removing the rocker boxes off of it.
« Reply #2 on: February 16, 2009, 02:36:05 pm »
Good job!
Offline frogman68
« Reply #3 on: February 16, 2009, 03:43:13 pm »
Thanks again guys I would of never got this far without your help
Offline hotrod24
« Reply #4 on: February 16, 2009, 05:22:38 pm »
good job man i hope i can do a job like that in the summer  ;)
1978 pontiac grand prix...
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
« Reply #5 on: February 16, 2009, 06:20:12 pm »
Looks good, looks like a nice fit from here.
« Reply #6 on: February 16, 2009, 08:56:49 pm »
Looks great. Nice to see the plug welds on top of the supports.
Offline frogman68
« Reply #7 on: February 17, 2009, 02:13:06 am »
Was a alot of cutting and grinding I didnt want to take all of the old floor out
This stubborn old Irish man did listen who says you cant teach a old dogs a new trick :)
