Author Topic: Intermittent Wiper Problem  (Read 10462 times)
Offline rockable
  • Truckin', like the do-dah man.
« on: February 16, 2009, 07:04:32 pm »
Hmmm.  I've read the other threads.
My wipers wouldn't stop wiping when I switched to OFF and the delay only has one setting - long.  Sometimes I had to jog it to MIST and release it to get it to stop and park.
I replaced the module tonight and it still does about the same thing.  It does seem to turn off and park (sometimes) now but the delay is not working any different.   Is there a ground somewhere that might be bad?  Where would I look?
Might the switch be bad?  I know they are a pain to replace.
Thanks
Rock
'86 SWB Silverado
Offline 84chevysilverado
Re: Intermittent Wiper Problem
« Reply #1 on: February 19, 2009, 07:29:01 pm »
not sure bout your problem might need a new motor. I got a similar problem when i shut off wipers the just stop the dont cycle back to the bottom and stop there anyone no what that is?
Offline Prong
« Reply #2 on: February 20, 2009, 04:31:55 am »
That's the park circuit. Replace the motor.
79 K10 SB 4x4 383/Th350
79 K10 LB 4x4 350/SM465
Offline rockable
« Reply #3 on: February 20, 2009, 06:21:04 am »
Mine will park, if I screw around with the switch.  Which leads me to think switch.  the motor is easier to replace.  I downloaded an article on how to check it out.  I'll get around to it soon.
'86 SWB Silverado
« Reply #4 on: February 20, 2009, 06:52:18 am »
It's probably the motor.
Offline rockable
« Reply #5 on: February 20, 2009, 10:12:18 am »
Vile, would the motor also affect the delay?  It seems to have one delay setting - long.
'86 SWB Silverado
Offline Texcuda
« Reply #6 on: June 14, 2009, 12:24:52 am »
did you ever figure this out? I have the exact problem in mine plus my wipers will come on randomly and I have the manipulate the switch to mist a couple times to get them to turn off. Thanks
BTW. mine is an 82 GMC with delay/washer
« Last Edit: June 14, 2009, 04:55:55 am by Texcuda »
« Reply #7 on: June 14, 2009, 01:21:55 am »
i know on my 94 the problem was the circut board i also had a mid 90's work truck that i would have to tap the motor/ circut board with a tool to get them to work. that don't help you out any i know but i would find the modular under the dash and give it a tap then try to tap the motor and see if one helps doubt it will but its a little help maybe here are some more post on this also
http://forum.73-87chevytrucks.com/smforum/index.php?topic=7132.0
http://forum.73-87chevytrucks.com/smforum/index.php?topic=6078.0
they will probably help more than i did ;D
