Engine/Drivetrain
Oil Pump Shaft Retainer??
Topic: Oil Pump Shaft Retainer?? (Read 6436 times)
76 3+3
March 12, 2009, 01:24:10 am »
Pulled oil pan off to replace rear main seal and Fel-pro provided an Oil Pump Shaft Retainer replacement. I can see this goes onto the oil pump shaft but I am not sure how to remove the old one. I am afraid I will break or damage the oil shaft. Any suggestions? This is on a Generation I Chevy 350 1975.
HAULIN IT
Re: Oil Pump Shaft Retainer??
March 12, 2009, 08:00:38 am »
Is the old one metal or plastic? If it's metal...leave it alone, if it's plastic...it will likely be dry/brittle & break when you start to remove it. They just slide off, if it gives you trouble you could cut it lengthwise to release it. Lorne
March 12, 2009, 09:25:38 am »
Thanks for the info. I ended up pulling the shaft apart (shaft snaps together under plastic retainer) and then breaking the old plastic retainer off.
March 12, 2009, 10:19:18 am »
I would replace it with a steel sleeve shaft. they're only $10-15 bucks.
⌠ŻŻŻŻŻ' [☼===☼]
March 13, 2009, 03:27:35 am »
I will keep the metal sleeve in mind next go around. I got the new plastic one on and rear seal/pan are back on. Thanks the info.
Engine/Drivetrain
