Author Topic: Replacing Fuel Tanks on TBI truck.  (Read 4682 times)
Offline 1HI4x4
  • V30 Crew now a shortbed.....
« on: March 30, 2009, 06:20:45 pm »
I bought a 1991 3+3, it has a 5.7 with TBI. I want to remove the dual tanks and install one tank either in the bed or behind the rear end. I will make either one out of aluminum, what will I need to do as far as the fuel pump? Can I run an in-line pump? If so what PSI? I know I will need to run a return line, but I'm seeing three lines on the tank, what is the third one for? Any help is appreciated.
1988 V30 Crew Cab, Cummins power, 47RH-NP205, 8" lift, 13.50x35x20 Fuel Mudders on 20x14 XD Diesels -76 offset. Soon to be repainted, seats from a 2010 Lariat to be installed.
Re: Replacing Fuel Tanks on TBI truck.
« Reply #1 on: March 30, 2009, 06:43:32 pm »
Why not run a blazer tank?
Offline ccz145a
« Reply #2 on: March 30, 2009, 09:21:29 pm »
Supply
Return
Venting/Evap Control
« Reply #3 on: March 31, 2009, 02:47:44 pm »
And for a TBI you need around 15lbs.  I would put a Blazer tank in it.  I would also use a factory intank pump.
« Reply #4 on: March 31, 2009, 05:36:24 pm »
Where's the link to the one you did?
« Reply #5 on: March 31, 2009, 05:48:04 pm »
