Author Topic: Building a Trazer...  (Read 63570 times)
Offline exilous
« on: April 25, 2009, 06:29:50 pm »
Has anyone here done it? or know someone who has done it? One of my friends suggested that I do it when im done building my dump. Seeing as how I will have 2 somewhat complete blazer chassis sitting in front of my shop. Although both of the blazer tubs and cabs are completely shot and rotted gone. So I figured I'd grab a somewhat decent cab while the blazer chassis is stripped throw a cab on it and sell it make a quick buck. I just want to know if the cab mounts are the same and if there are any other things that would need to be modified or changed in putting a pickup cab on a blazer frame.
Re: Building a Trazer...
« Reply #1 on: April 25, 2009, 07:57:46 pm »
Are you talking about enclosing a blazer? Because that's how most of them I've seen have been done.
Offline exilous
« Reply #2 on: April 26, 2009, 06:20:56 pm »
Well I guess that would work. A couple guys I know know about a trazer or CK5. Whatever you want to call it. You take a regular cab off a truck and mount it on a k5 frame and it has like a super short bed looks kinda retarded in my opinion I tried googling it and came up with some pics nothing showing really how to do it or go about doing it. Just wondering if anyone here has done it or seen it done.
I wouldnt mind enclosing a blazer but both my blazer bodies are destroyed from rot but the frames are both very good. and right now up here no one is really buying anything for parts or buildups or anything. For awhile I tried to give away my whole rolling K5 chassis from my last parts blazer the thing was beautiful not a  spec of rot on it...i couldnt give the axles or hubs or nothing away i ended up scrapping the whole rolling chassis for $45 at a scrap yard and I don't want to do that again. and I dont really have a spot to hold onto them forever till i find a buyer for something. so i figured i'd slam a truck cab on it and call it a day since i have plenty of parts to build one up or at least put it together to make it leave.
Offline fitz
« Reply #3 on: April 26, 2009, 08:54:16 pm »
 I would love to see it done. I've seen a few but they were real beaters. I've kicked around the idea of doing it to my 94 full size Blazer.
 You mentioned selling it when you are done. I don't think they would be worth any $$. Like you said, you can't give these parts away now. If your building this rig as a way to sell of all of your spare parts, it's a tough call.
Offline exilous
« Reply #4 on: April 26, 2009, 09:39:29 pm »
ya i know, thats why i wanted to see if it would be easy to do the swap. i've got a cab ive got extra fenders hoods grilles drivetrain will all be there just gotta through the sheetmetal on and go. I mean I'll ahve all my paint gear out anyway from painting my C30 so I'll slap a quick coat on the "Trazer" and send it on its way. but if there is a ton of mods i'd have to do along with lots of customization to the frame I guess i'll just hold onto the parts I have and see if i can off them 1 at a time.
I'll put it to ya this way, i'm renting a shop to do my C30 project truck and to get away from it all a place to just be alone and work alone. when the project is done all the bigger items ( cabs frames fenders hoods) and the like won't be able to travel back to my place. only small like interior pieces and emblems and stupid stuff that sells good would be able to come home. so the longer i hold onto that stuff the less money it would potentially make me.
« Reply #5 on: April 27, 2009, 04:04:13 pm »
See it done, yes, like it no.
Will the cab bolt up yes, will be bed, No.
Offline exilous
« Reply #6 on: April 27, 2009, 07:56:03 pm »
Ya I kinda figured the bed wouldn't. I figured I would end up making some sort of crappy flatbed or just putting the cab on and trying to sell it like that. I did find a website that had some pics and it was a bunch of mixed reviews on the conversion. take a look at the pics and see what you guys think.
http://coloradok5.com/forums/showthread.php?t=188960&highlight=Cab+on+Blazer+frame
interesting concept to say the least. I like how the one guy did it with a pickup crossmember he did a good job.
« Reply #7 on: May 09, 2009, 02:01:57 pm »
I have done two C 10 cabs on K5 frames. Both of them I used the two wheel drives rear cab mount / cross member. I mounted the front cab mounts, and the core support mounts. Then raised / lowered the cab until the door fender line was correct. Bolted the cross member to the rear cab mounts, and welded it to the frame, made a few gussets to fill the gap as it lands right about where the frame curves up. First one I put a steel flat bed on. The second one I slid the rear spring perches back on the frame about 4". I used a step side body, deleted the steps, and slid the fenders forward on the box. At first glance it looked like a regular short bed. Then you had to do a double take. to see what it was.
Offline exilous
« Reply #8 on: May 09, 2009, 04:27:12 pm »
ohhh very cool idea, so you just had to put that crossmember in and measure the height so the body lines matched up? everything else bolted up pretty well im assuming
« Reply #9 on: May 09, 2009, 06:58:56 pm »
I didnt know what you were talking about at first, but now I do. I have a friend that has built a few. Here is his current project. Sorry for the poor pics
« Last Edit: May 09, 2009, 07:02:06 pm by choptop »
Offline exilous
« Reply #10 on: May 09, 2009, 07:36:04 pm »
 :o :o :o :o
Wholey balls, what are those like 53s he runnin there? I really like the bed that he made. those fenders are nice accents with the diamondplate on top looks sweet. But yes that is what i'm talking about.
« Reply #11 on: May 09, 2009, 08:19:11 pm »
Im not sure on the tire size, I forgot. He has a tendency to build everything overkill. It all works well, and will handle alot. The funny thing about this one is that it has all of the best parts in ut for some serious offroading, bigblock(500+hp),built 4l80e ( I think) Dana 70 rear, Dana 60 front the works, but will just be a street queen. He has built, sold, repurchased, and now rebuilding this truck for many years.
Offline eventhorizon66
« Reply #12 on: May 09, 2009, 08:32:29 pm »
The funny thing about this one is that it has all of the best parts in it for some serious offroading, bigblock(500+hp),built 4l80e ( I think) Dana 70 rear, Dana 60 front the works, but will just be a street queen.
That's nuts.  Time to have your friend committed.
'85 C10 SWB 350 700R4 TKO600
« Reply #13 on: May 09, 2009, 09:37:17 pm »
We've been trying to do that for years :D ;D. They say theres no help for him
Offline exilous
« Reply #14 on: May 10, 2009, 03:13:41 pm »
thats way kool. I know a few people that have bought sold rebought and bought again at some point vehicles. It's kinda cool to keep getting your old vehicle back. Definetly a nice rig he has there though. very nice i like it.
