Members Rides
1987 R10 Driver
21
22
23
24
26
Topic: 1987 R10 Driver (Read 536939 times)
NASTY-LSX
Re: 1987 R10 Driver
Reply #315 on:
August 22, 2015, 05:16:38 pm »
Thanks Kaos!!
Cody the Roady
Re: 1987 R10 Driver
Reply #316 on:
August 26, 2015, 03:47:15 pm »
What's your plan with the exterior?
America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves.
Abraham Lincoln
Re: 1987 R10 Driver
Reply #317 on:
August 27, 2015, 10:46:36 pm »
Eventually plan to paint it. Tan and Red 2 tone.
travisr1988
Re: 1987 R10 Driver
Reply #318 on:
September 01, 2015, 09:47:07 pm »
How do you like the air filters under the truck? Would it be better to build a housing for them, or do they seem to work well and stay dry exposed like that?
1979 Chevrolet Silverado C20 rclb cammed 355/th400/4.10 - sold
1977 Chevrolet Custom Deluxe c10 rcsb stepside 355/th350/3.42
Vortec heads lunati cam edelbrock intake headers
Re: 1987 R10 Driver
Reply #319 on:
September 03, 2015, 06:57:43 pm »
Well every STS truck and car we have installed a remote kit on has them underneath and haven't had any issues with them.
I drive it everyday and haven't had any issues with it at all they are mounted up in the gas tank humps.
travisr1988
Re: 1987 R10 Driver
Reply #320 on:
September 04, 2015, 08:39:32 am »
Thank you, I was concerned with them getting wet under there, but I suppose water probably wouldn't get up that high. Anyways, the build looks sweet and I really like the turbo setup, only thing I would do differently is hide the plumbing somehow, maybe just paint it black so it catches no one's eye.
Re: 1987 R10 Driver
Reply #321 on:
September 04, 2015, 03:47:21 pm »
Short of running through 10" deep rivers my should not get wet.
The one side of piping was supposed to mimic the other side with a bend and I was going to blend it in with black paint, but oh well...
Re: 1987 R10 Driver
Reply #322 on:
December 09, 2015, 09:04:32 pm »
Saturday, March 21st, 2015:
Headliner finally gave up and started falling on the truck so this day I removed it.
Re: 1987 R10 Driver
Reply #323 on:
December 09, 2015, 09:07:04 pm »
Friday, April 10th, 2015:
Random parking deck picture. Truck is NASTY... But I do drive it everyday.
Re: 1987 R10 Driver
Reply #324 on:
December 09, 2015, 09:08:23 pm »
Saturday, April 11th, 2015:
Went to the local cruise-in and met up with my Twin (2000 Silverado) and my buddy Kevin in the 67-72
Re: 1987 R10 Driver
Reply #325 on:
December 09, 2015, 09:14:45 pm »
Saturday, April 18th, 2015:
Windows were getting really foggy over the past few weeks and I discovered that the heater core I replaced barely a year ago is now leaking in the floor, A LOT! My daughter wanted to help take bolts out so...
Pulled back the carpet and found this... Again...
This felt in the flooring was pretty bad, so I just cut it off and removed it.
Luckily the floor was easily cleaned back up.
Since it was LS powered I couldn't just cap everything off and the loop I had in the waterpump last time was collapsed, so I had to wait until the the parts store could get me the U hose and I just pulled the existing lines off.
Re: 1987 R10 Driver
Reply #326 on:
December 09, 2015, 09:18:21 pm »
Sunday, April 19th, 2015:
The U hose came in and I wasted no time putting it back on. Since I didn't have AC and I had a leak I left it like this until it got cold.
Re: 1987 R10 Driver
Reply #327 on:
December 09, 2015, 09:25:03 pm »
Saturday, May 9th, 2015:
I went and picked up my spare bed so I can do some modifications to it that will allow me to drive anywhere and fill up the tank. Previously I had two gas stations that I knew I could fill up at and it would only take me about 8 minutes to get gas as it wanted to spill out. I had plans to go on Power Tour and I needed to be able to go anywhere.
Bed lacks much in the way of pretty, but I won't mind cutting it up as I found it from a friend and it was rotting in the woods.
Last Edit: December 09, 2015, 09:28:52 pm by Captkaos
Re: 1987 R10 Driver
Reply #328 on:
December 09, 2015, 09:28:37 pm »
Tuesday, May 12th, 2015:
I spent the afternoon doing some serious washing on the bed. I also talked to a place that said they would fill the door on the drivers side and put the gas fill hole on the passenger side. I just needed to find a donor opening and either fab a gas fill or find one from a Blazer.
Re: 1987 R10 Driver
Reply #329 on:
December 09, 2015, 09:35:56 pm »
Wednesday, May 13th, 2015:
Seeing that I am going on Power Tour I figured I would need to charge my AC, so I vacuumed down the system and let it set overnight. I ended up charging it later on prior to going to Power Tour but the pulley setup was giving me fits. I had issues with the original Novack setup so I called them and the told me they would send me an updated setup that used a different pulley. So far other than a weird vibration when the AC is on at the idler everything works ok.. I also ended up NOT using it during Power Tour, just ran with the windows down.
I also dropped the bed off with the body guy that evening.
21
22
23
24
26
Members Rides
1987 R10 Driver
