Author Topic: Electric fan & Water pump installation  (Read 35138 times)
Offline HAULIN IT
« on: May 17, 2009, 01:48:46 am »
Here's my latest project...Some of the Water pump won't apply to most of you, but I thought I would share my fan findings. It may not be the absolute best fan set-up, but it's a really good fit (with some home-made bracket/shroud) for our trucks. I found this by pretty much an accident (no pun intended). It is from a '99 Seville. I brought it home, having a couple broken spokes of the shroud from a wreck & found as I was figuring...just how well it fits & is sized well. I did remove some irregular "growths" from the shroud, like a indent (in the wrong place) for the upper rad hose & a molded in triangle hose holder & some other unneeded molded in tabs/holders.
 Here are a couple in the fitting stages
 A trip to the salvage yard netted the plugs & wiring all the way to the firewall, another Buick or Olds donated a relay/fusible link set-up that I ran from the distribution block above the master cylinder. I have a variable speed controller to install after the initial testing. The Caddy had Two 30 amp fuses on the fans, so it appears they have some draw, I will test & report on said amount.
 Here is a couple shots of the home-made alternator bracket & modified power steering bracket
 Installed for test-fit & belt lengths... That is a small block Chevy water pump adapted to the Olds engine
Re: Electric fan & Water pump installation
« Reply #1 on: May 17, 2009, 08:57:40 am »
Did you use the radiator and upper support form the caddy too? Looks like it fit nice. What kind of control are you going to use?
Offline HAULIN IT
« Reply #2 on: May 17, 2009, 03:08:48 pm »
Vile, It's the same radiator that I put in when the truck was built...a Aluminum/plastic tall replacement for our trucks. The top support is Chevy truck also, originally I bought the radiator, top plate & shroud for a big block truck.
 What I did was start with a 2'x3' sheet of 16ga metal & cut out the center hole, folded lips on it, ect. The top area is a piece of light angle iron cut to match the Chevy top plate. The sides have a piece of 1/2" square tubing for support & to close off the shroud...basically I laid the original shroud down on the metal & marked the mounting holes & tank width, then laid the Caddy fan assy. on & figured what was needed to mount it where it fit & went from there. I thought I had a picture or Two of the metal part separate, but I didn't find them. The Black area in the photo is metal, the Gray is the Caddy shroud. I painted the other side of the Caddy shroud so it all looked the same.
 The controller I got is a Flex a lite pt# 31163, It has some nice features...comes on "soft start" & ramps up, then stays on after the Ign. is shut off until the sensor reads the temp. is back down. I'm going to use it to trigger a relay to allow the water pump to run also until the temp. is down, then shut off.
 I'll post the findings of the "amp test" & final assembly soon. Lorne
Offline SUX2BU99
« Reply #3 on: June 03, 2009, 02:40:23 pm »
Very cool, Lorne! In the recent issue of Hot Rod where they fix up a 73 2wd stepside, they found a dual-fan Flex-a-lite setup I believe that apparently fit the stock rad pretty much perfectly. Aftermarket dual-fan setups are a heck of a lot more expensive than a junkyard OEM find though.
Something weird I experienced: when reading your text on your last post, the blades on the two fans start to spin very slowly when looking at them with your peripheral vision as I read the text left to right. Trippy!  :o
Offline HAULIN IT
« Reply #4 on: June 16, 2009, 12:38:46 pm »
Sux, I did see that article. Those are 12" fans & way the shroud is (very flat) & installed, it leaves allot of surface area not having air pulled across it. Also I personally am not a fan of their attaching method (those plastic ties through the core) with the weight & vibration of the fans, could lead to a need for radiator repairs. A bracket/mounting plate of some sort would be better, it leaves the radiator to "float" on the rubber cushions & the fan weight/vibration is left to the rad. support. It may not cause a problem this week or next...maybe never, but still not the way to go.
 On a side note, I saw in one of the pictures that they have the rear shocks mounted upside down. Who knows maybe they know something Rancho, Calvert & the rest of us don't ;)  It's a shame to see things like that fan install, the shocks (maybe) & autobody repairs (since I do that), because when you read something that you don't know much about, you have to be leary that there are flaws in that article/advice also. We, as readers have to keep in mind at all times that those magazines/TV shows are "paid advertisements" for whoever is paying to advertise with them...Sometimes it's the "right" answer & sometimes it's just the one you are sopposed to hear for someone else's benefit. My Two Cents, Lorne
Offline SUX2BU99
« Reply #5 on: June 19, 2009, 01:56:21 pm »
I hear you about being leery of the validity and accuracy of magazine articles. Usually a person just takes them at their word and that they are experienced and know what they are doing. Rarely do they publish mistakes they made, things they broke, or problems that surface months down the road from improper installation. Sometimes on things I know a little bit about (like car audio as an example), I'll see errors printed and just shake my head at the misinformation someone else is reading. I dig your fan install and if I happen upon a late model Caddy at the boneyard, I'll for sure have a look at their fan setup.
Offline HAULIN IT
« Reply #6 on: July 03, 2009, 10:15:58 am »
I found the pic's of the fan bracket in bare metal (they were on another disc for some reason). This should make it a little clearer as to what was done. Lorne
Offline Stewart G Griffin
« Reply #7 on: August 13, 2009, 10:20:18 am »
1) Could we get a break-down of all the parts nessesary, specifically part #'s?
2) i think the main thing is an exact, step-by-step instructional on how to install electric fans the right(safe) way.  Specifically, the whole fuse/relay issue, so as to prevent a fire.
3) Why again, did you have to fabricate an alternator mount?
Offline eventhorizon66
« Reply #8 on: August 13, 2009, 11:03:15 am »
Electric water pumps don't have provisions for the alternator bracket like the stock pumps do.
'85 C10 SWB 350 700R4 TKO600
« Reply #9 on: August 13, 2009, 03:01:13 pm »
Look at the schematic in my electric fan install
Offline drag80
« Reply #10 on: September 26, 2009, 01:42:30 am »
you can buy a alternator bracket that bolts on using the water pump bolts, I beleive moroso makes it..but it's not cheap though
Offline team39763
« Reply #11 on: September 26, 2009, 12:50:13 pm »
Nice work Lorne.  I like what you did with the waterpump.
Offline Skunksmash
« Reply #12 on: October 04, 2009, 07:00:14 pm »
Is this truck daily driven? I have wanted to do an electric water pump for my truck, which will be set up to be a daily driver.
Offline HAULIN IT
« Reply #13 on: October 05, 2009, 10:27:43 am »
Skunk, Absolutely! I took the family out to supper last night in it, we drive it virtually every day when the weather is nice. NEVER overheats, goes down the road around 160*. We just came back from a week long trip where we trailered it to Muncie In. then drove it over 1100 miles in a circle, racing it every day...ending up back in Muncie on Friday. This was mostly regular back roads through towns, Amish buggies, old guys in rocking chairs at the gas station, ect. & some (a few hours) freeway driving @ over 70mph. You can check out my other post & then go to the 1320video link...also the January issue of Hot Rod is to have the  coverage in it.
 However, I wouldn't bother doing for a regular, daily driven (not raced vehicle) I just don't see the need, nothing really wrong with the stock set-up. The main reason I went with the electric was to be able to circulate the coolant between runs at the track. My Two cents, Lorne
  http://forum.73-87chevytrucks.com/smforum/index.php?topic=13608.0
Offline Skunksmash
« Reply #14 on: October 05, 2009, 11:27:06 pm »
Well, I saw some TV show (I think it was "Horsepower") where they used an electric water pump on a daily driven camaro to raise the fuel mileage. They did a few other things too, but that was part of their plan. And it worked out by giving the car 2.2 MPG after all the little things they did. So I think it might be worth it, say when the mechanical water pump I have now finally dies.
But have you had to put a bigger alternator on, now that you have a lot more electrical stuff running on your truck?
