Author Topic: Rebuild project questions drive line bearing  (Read 9337 times)
Offline greenkeeper
« on: May 17, 2009, 07:50:03 am »
I am working on my 87 R-30 . I have pulled the front drive line and in the middle between the front and rear drive line is a pillow block bearing. It needs to be replaced but everywhere i've gone to get parts i've struck out.  What is this bearing called and where can i find one. Its not even mentioned or shown in a Chiltons manual ???
Offline oldwhity
Re: Rebuild project questions drive line bearing
« Reply #1 on: May 17, 2009, 08:35:47 am »
Carrier bearing? Is it a two piece drive shaft?
Rob G.
81 Chevy K20 4x4 LWB stepside
Offline greenkeeper
« Reply #2 on: May 17, 2009, 09:02:32 am »
Yes its a 2 piece drive.  I am trying to get a picture uploaded to show what I am talking about.  It appears that the bearing is blown. It is original to the truck so its way over due for replacement.
« Reply #3 on: May 17, 2009, 09:04:24 am »
Offline greenkeeper
« Reply #4 on: May 17, 2009, 09:13:41 am »
Thats what Im looking for. Where can I find it Villie?
Offline greenkeeper
« Reply #6 on: May 17, 2009, 09:53:55 am »
Vile,
I called everyone. NAPA was the only one who could special order one for $148.00
Is the one listed on the web page the one I need ? And why would is it a lot cheaper? I want to make sure I get one that is heavy duty. Its for my dump truck.
thanks, Steve
« Reply #7 on: May 17, 2009, 11:40:08 am »
Really? I get them anytime no problem. Lemme look it up from one of my vendors. It is an 87 R10 350 carbureted right?
Offline greenkeeper
« Reply #8 on: May 17, 2009, 11:44:22 am »
Its an 87 R-30 350 5.7L 4speed carb
Thanks
« Reply #9 on: May 17, 2009, 11:47:16 am »
Do you have an Acme auto in your area? My acme has one in stock for $40.09
Center Support With Bearing
BCA ­ HB88107A 87-91    $40.09
Acme Auto Parts Enfield
SPICER 1280, 1310, 1330, 1410 SERIES / BRG ID 1.3780\" 35MM - SLIP YOKE STYLE - BALL BEARING
They have a generic one for $15 bucks also and just the bearing for $10 bucks.
Offline greenkeeper
« Reply #10 on: May 17, 2009, 01:19:15 pm »
Yes , I have an ACME near me.  I will give them the info you gave me and hopefully they will have it. Otherwise, ill be headed to Enfield. Thanks for the info.steve :)
« Reply #11 on: May 17, 2009, 02:23:56 pm »
You shouldn't have to go to enfield. if Acme doesn't have it they have a warehouse in stratford and can get it the same day *#*
Offline exilous
« Reply #12 on: May 17, 2009, 05:08:19 pm »
ive gotten carrier bearings before from even pepboys. and pepboys usually doesnt have anything. $148 sounds like they don't know what they are talking about too that seems very steep.
Offline greenkeeper
« Reply #13 on: May 23, 2009, 01:39:01 pm »
I picked up the bearing at ACME a greasable one was $70 and I also picked up u-joints.  Any tricks on getting the old rusty ones out?  The clips have rusted away. I've been spraying P-B Blaster on them for days. >:(
« Reply #14 on: May 23, 2009, 04:47:03 pm »
If you need help make the trip and I'll help you get it all set up.
Do you have the internal clips? Use a sharp screwdriver and a hammer and smack them out. Take an old 5/8" or so impact socket and secure it in a pair of vice grips. Get your BFH and support the yoke ends of the shaft. Use your vice to punch it through one side through the opening in the vice and remove the cap. Flip the it over and send the trunion back through the other way and remove the opposing cap. Once it's off it'll come out.
