Engine/Drivetrain
egr installation
Topic: egr installation (Read 7714 times)
rustys82
egr installation
May 31, 2009, 10:58:54 am »
ok. i have 82 c10 swb. has a 350 crate. edelbrock manifond and holley carb. question is, where do the hoses hook up to on the carb and/or manifold from the egr. also where does the hose from the vapor can hook up to on the carb or manifold? please help me.
82gmc3/4ton
Re: egr installation
May 31, 2009, 11:07:29 am »
do you live in a area with visual under hood inspections?
rustys82
May 31, 2009, 11:22:38 am »
yeah. they do do a visual. thats all im concerned about. i have own the truck since 2004 and i have only put under 5000 miles on it.
May 31, 2009, 11:52:15 am »
You will have a thermostatic vacuum switchin valve connected to ported vacuum. The other port will go to the egr valve. Do you have the vacuum hose routing diagram on the veci label?
rustys82
May 31, 2009, 12:09:00 pm »
my veci label is hard to read. i tried to find a new, but still no luck. i just went a picked up my shop manual at my dads house. im going to check in there. also just got the new summit catalog in the mail so i got look through it and dream a little. vile you said before on my other post that i could get a new veci label from a resto shop. what do you mean. i tried to google it but came up with nothing. do you have any links.
May 31, 2009, 02:09:53 pm »
Can you read the part number on your old one?
May 31, 2009, 02:17:56 pm »
http://www.parts123.com/parts123/yb.dll?parta~dyndetail~Z5Z5Z50000050g~Z5Z5Z5AAXFT~P10.75~~~~~~~F
rustys82
May 31, 2009, 02:47:09 pm »
from what i am able to make out is. the vapor can has 5 hose on it, i have 1. pcv supposed to have 2 ports, mine 1. distributor suppose to be vac advance, me no. im trying to find pictures of what all of these parts are. ie dist delay valve, egr/purge control valve tvs, purge signal hose, check valve, efe. oh and there is black round thing mounted above the ac/heater box on passanger side of the firewall. i think i might be screwed here.
rustys82
May 31, 2009, 02:52:35 pm »
i would post pics but the last time i tried it didnt work. i tried to post 2 pics with a post in readers rides but my post never came up.
May 31, 2009, 04:35:05 pm »
Host your images on photobucket and then just use the image code with the link inside it like this:
[ img ] http:// your link here . jpg example [ / img ]
no spaces
rustys82
May 31, 2009, 04:44:36 pm »
well i figure out some of my mess. i looked at every page of my shop manual. remember im new at this. the one thing i was concerned about turn out to be the vacuum can for the a/c. the other was the vac switch for the ESC with isnt used anymore. and the other turned out to be the vac switch for, you guessed it, cruise control. but i still have to figure out the plumbing for the fuel vap can and the egr. and all the other stuff. oh yeah, i figured out the pics thing. check out my truck at members rides.
rustys82
June 01, 2009, 08:29:37 pm »
ok here is the label
rustys82
Reply #12 on:
June 01, 2009, 08:32:31 pm »
the only things i have are the egr, vapor can with ONLY the fuel tank hose and the efe. there is a pcv but not the right one
rustys82
Reply #13 on:
June 01, 2009, 08:35:34 pm »
engine pics
Engine/Drivetrain
egr installation
