Author Topic: 8" American Racing wheels Hitting Tie Rod End  (Read 21072 times)
Offline timl1978
« on: June 02, 2009, 12:03:53 pm »
Has anyone had this issue with 8" wheels, no offset, on these year chevy's?  I had to go to 1/4" spacers and grind the edge or the TR end to make them clear.  Could the TR ends be aftermarket and too fat?  Now I have barely enough lug thread left, like 3-4 turns total.  I spoke to the wheel dealer and they said they've never had this issue with this wheel and these trucks.
Offline HAULIN IT
Re: 8" American Racing wheels Hitting Tie Rod End
« Reply #1 on: June 02, 2009, 02:59:28 pm »
Tim, If you only have 3-4 treads into the lugnut...DO NOT DRIVE THE TRUCK! This is unsafe & will cause you much bigger problems. Unless your talking MINOR grinding on the tie rod end, I don't like the sounds of that either. Sounds like you need different wheels, at least get longer studs. Lorne
« Reply #2 on: June 02, 2009, 03:59:52 pm »
8" wheels with no offset? Are these for a wheel barrow?
« Reply #3 on: June 02, 2009, 04:23:22 pm »
How about some pics to help clarify things. Definatley dont drive with the lug nuts barely engauging.
« Reply #4 on: June 02, 2009, 06:19:42 pm »
You already heard it but it is worth saying again.  DON'T drive it with the lugs barely on.
Offline oldwhity
« Reply #5 on: June 02, 2009, 09:05:59 pm »
LMAO
Rob G.
81 Chevy K20 4x4 LWB stepside
Offline ms4972
« Reply #6 on: June 02, 2009, 10:00:58 pm »
Sounds like a back spacing issue
Offline timl1978
« Reply #7 on: June 03, 2009, 06:50:44 am »
Here is a photo of the issue.  These wheels are the exact wheels that americanracing.com's fitment guide says fit this vehicle.  I am thinking that maybe the TR Ends are replacement and have a larger diameter than OEM or American Racing sucks and they don't know what fits what.
Offline timl1978
« Reply #8 on: June 03, 2009, 06:55:09 am »
The wheels...American Racing Baja part#AR1726883.
Offline timl1978
« Reply #9 on: June 03, 2009, 07:01:37 am »
Wow that was extremely helpful!  Actually I believe my wheel barrow has 3" wheels with no offset.
« Last Edit: June 03, 2009, 07:14:43 am by timl1978 »
Offline fitz
« Reply #10 on: June 03, 2009, 07:18:09 am »
Is it the rim that hits the tie rod or the wheel weights that are hitting? I've had problems with the clip on wheel weights hitting the tie rod before. I solved the problem by removing them and using the stick on type of weights.
« Reply #11 on: June 03, 2009, 07:20:52 am »
The wheels have the wrong offset for your truck (I know, Mr. Obvious here) I have  -51mm offset on my red truck and have no issues at all. The zero offset is common on the 90s 4x4 and up. Since you have 16s and not the standard 15s they came with, I believe they gave you the wheels for a newer truck and thats why youre having the problem. 16s are standard on 99 up. They need to put the correct wheels on for you. They made the mistake, they need to fix it.
Offline timl1978
« Reply #12 on: June 03, 2009, 03:28:20 pm »
What your saying makes sense.  I spoke to the dealer and they are calling ARE, because that would mean there application data is wrong I guess.  Thanks.
Offline 79K20
« Reply #13 on: June 03, 2009, 05:35:31 pm »
That is really interesting... I do believe that the 0-offset should fit these trucks, but obviously yours aren't fitting. I'm surprised that they let you leave their shop (1) with wheels that rub, and more importantly, (2) with lugs that aren't fully engaged? They are just begging for a lawsuit! Seriously DON'T drive the truck with the lugs in that condition.
The bottom line is that every single vehicle is different; the fitment charts are never absolute. So, the wheel dealer needs to fix their mistake either by ordering you new wheels (i.e. ones with NEGATIVE offset, like -12 or more) or they need to work with you on using spacers and longer studs, etc, to make these wheels fit.
Offline 79K20
« Reply #14 on: June 03, 2009, 05:52:26 pm »
The plot thickens... I just checked two other manufacturers (Eagle Alloys and Pro Comp) and BOTH suggest a -11mm offset for the 6-on-5.5 16x8...
http://www.aewheel.com/wheels_detail_specs.cfm?id=23
http://www.procomptires.com/truck-jeep-wheels/pxa-series-1069-wheels.aspx
I think that ARE has there fitment charts wrong... These shouldn't be a 0-offset w/4.25-inch backspacing; should be a -11mm offset and 4.0-inch backspacing.
