Author Topic: What do yall use to paint your engine blocks?  (Read 28342 times)
Offline exilous
Re: What do yall use to paint your engine blocks?
« Reply #15 on: June 15, 2009, 07:14:02 am »
I cna't wait to make my engine all painted and pretty
Offline Skunksmash
« Reply #16 on: June 15, 2009, 03:25:51 pm »
What cleaning steps do you take when you clean a block for prep, vile? Maybe just a wire brush and some oven cleaner, like the other member said? Then wash it with plain water and towel dry perhaps?
Offline 1HI4x4
  • V30 Crew now a shortbed.....
« Reply #17 on: June 15, 2009, 03:33:10 pm »
I have good luck using accetone and some wire brushes, if you use oven cleaner make sure you get all the residue off the motor or the paint won't stick.
1988 V30 Crew Cab, Cummins power, 47RH-NP205, 8" lift, 13.50x35x20 Fuel Mudders on 20x14 XD Diesels -76 offset. Soon to be repainted, seats from a 2010 Lariat to be installed.
« Reply #18 on: June 15, 2009, 03:44:16 pm »
Personally I use aircraft remover after the initial gunk down. If it's going to the machine shop I have it hot tanked also. Pressure wash it with simple green and make sure there is NO residues. Once it's dry, prime and paint. I usually do 3 coats.
Offline Blue 82
« Reply #19 on: June 15, 2009, 06:12:00 pm »
When i was younger, Plasticoat Orange was my color of choice. It always looked "wet"
On boats, we would paint everything white after red primer.
Anymore, I just paint em black,
Rustoleum Hard Hat works for me (after a red primer of course)
« Reply #20 on: June 15, 2009, 07:55:25 pm »
I have used Simple Green but my opinion Castrol Super Clean works better.
Offline Jay2D2
« Reply #21 on: June 15, 2009, 08:24:44 pm »
X2
Offline Skunksmash
« Reply #22 on: June 15, 2009, 08:34:59 pm »
I guess it leaves no residue?
« Reply #23 on: June 15, 2009, 09:48:16 pm »
None of them leave a residue if they are rinsed off good with hot hot water. I use break clean to hose any mechanical part down before I paint it. Oil pan, valve cover, intake what ever. A good auto body prep solvent works fine too.
Offline Skunksmash
« Reply #24 on: June 16, 2009, 02:22:30 pm »
Let's see some pics of some nice painted engine blocks!
Offline Skunksmash
« Reply #26 on: June 18, 2009, 03:03:38 am »
What color gold should i use, if i want to be true to the whole Oldsmobile thing?
