Author Topic: rearends????  (Read 8378 times)
Offline rustys82
rearends????
« on: June 14, 2009, 11:16:31 am »
does anybody know what rearends from any other types of vehicles would bolt right in to my 82 c10. i have a corp 10 bolt with 8.5in ring. it must be able to bolt right in. prefering 3.55 gear set.
Re: rearends????
« Reply #1 on: June 14, 2009, 12:31:22 pm »
Anything from 81-86 C series and 87-91 R series will bolt in.
SOME 81's had 12bolts, so verify first.
Offline DnStClr
Re: rearends????
« Reply #2 on: June 16, 2009, 10:18:59 am »
Rusty, what are you looking at doing- getting a used set of ring and pinions? I hope not. Maybe I misunderstood your post.
Don
87 Chevy Silverado
Offline rustys82
Re: rearends????
« Reply #3 on: June 16, 2009, 03:36:25 pm »
no, my rear needs to get rebuilt. pinion seal is leaking. i was going to try to find something in the junk yard. i might be better off just having mine rebuilt. you never know what you will get from the junk yard.. bye the way this was probably asked before. but what is the stock gear ratio for corp 10 bolt 8.5in.
Re: rearends????
« Reply #4 on: June 16, 2009, 03:39:46 pm »
3.08:1, 3.42:1 and 3.73:1 were the most common 10 bolt ratio's
Why replace the rear end over a leaking pinion seal that'll cost you $5 bucks?
Offline rustys82
Re: rearends????
« Reply #5 on: June 16, 2009, 04:57:51 pm »
how do you replace the pinion seal without removing everything
Offline Blue 82
Re: rearends????
« Reply #6 on: June 16, 2009, 06:10:57 pm »
Remove driveshaft
Mark location of big nut to pinion shaft
Remove big nut
Remove yoke
Remove seal
install seal
install yoke
install big nut to the align with the marks
install driveshaft
check fluid level
Offline oldwhity
Re: rearends????
« Reply #7 on: June 16, 2009, 07:50:20 pm »
Yeah, what he said. I just did mine about a month ago. You'll need a big socket for that "big nut".
Rob G.
81 Chevy K20 4x4 LWB stepside
Re: rearends????
« Reply #8 on: June 16, 2009, 09:40:21 pm »
A big impact gun to go with the big socket helps allot too!
Offline fitz
Re: rearends????
« Reply #9 on: June 16, 2009, 11:44:20 pm »
After you mark the nut and the housing as a reference point, count the turns as you back off the nut. After you replace the seal spin the nut back on the same amount of turns. This should help avoid over tightening the crush sleeve.
Offline rustys82
Re: rearends????
« Reply #10 on: June 17, 2009, 06:13:31 pm »
wow that easy. for some reason i thought i would have to remove the pinion gear to replace the seal. thanks a million.
