Author Topic: Winow and door lock relays. Wshere are they?  (Read 13309 times)
Offline BigBadJohn
« on: June 17, 2009, 04:30:16 pm »
Are they in the doors or under the dash? Because I doubt the PO knew to take them out if they were under the dash
I guess Ill hard wire them otherwise
Just picked up a Hayes manual. Should help out a lot
Re: Winow and door lock relays. Wshere are they?
« Reply #1 on: June 17, 2009, 07:54:32 pm »
Can you be a little more specific on everything?
Offline BigBadJohn
« Reply #2 on: June 17, 2009, 09:54:55 pm »
75 pickup with 84 body. Doors have power windows and locks. I was wondering where the power lock relays was that swapped polarities around to lock/unlock the doors because I think one of the previous owners cut he wires off at the doors and didnt think to keep the relays/harnesses for the windows and locks
I ended up making my own lock relay out of (4) 12v relays
I wouldve gotten done with the window and locks if I had 2 more hours of daylight to work. Guess Ill try and finish it next week
Heres the relay I made. Almost done. Can only use one lock switch though. Otherwise if you try to say unlock with the passenger door and lock with the drivers door, it will short positive to negative
Works out because the idiot hacked the passenger door switches and harness up anyway
All of the tracks and motor for the passenger door are also missing. Thats something the seller forgot to tell me  >:(
Offline DnStClr
« Reply #3 on: June 18, 2009, 07:13:36 pm »
The shop manual shows mine, a single relay,(1987) behind the dash attached to the brake pedal bracket. It looks like the heat/ac ductwork would have to come out to get to the relay.
Don
87 Chevy Silverado
Offline DnStClr
« Reply #5 on: June 19, 2009, 12:15:39 pm »
Whew. No wonder it's got a 30 amp breaker.
Don
87 Chevy Silverado
Offline BigBadJohn
« Reply #6 on: June 22, 2009, 11:49:04 pm »
Finally got the drivers window and both door locks wired today
Heres my home made relay
Offline brlarl
  • Big Bad Bowtie!!!
« Reply #7 on: June 23, 2009, 02:37:12 pm »
Man your window hauls arse... did you change the regulators and motors?  What about the window felts?  I wish my windows moved up n down that fast.
Don't wear a tux without the BOWTIE!!!
Offline BigBadJohn
« Reply #8 on: June 23, 2009, 07:58:04 pm »
I took my grease gun and shot grease into all the tracks where the rollers move
I then sprayed every moving part in the door I could see with wd-40
