Author Topic: transfer case problem  (Read 4246 times)
Offline veachmasonry
« on: June 23, 2009, 11:36:12 am »
I have a 1984 Chezy 3/4 ton 4x4. I just put a 350 turbo transmission and transfer case in it that came out of a 1979 chevy. I didn't realize that the transfer case was for a fulltime 4x4 until after i put it in my truck. To put my truck in 2 wheel drive, i have to lock my hubs in. I'm currently trying to find another transfer case that will work. Is there a way to look at the transfer case and be able to tell if its fulltime 4x4 or for manual hubs? Ive also heard that there is a way to make a fulltime 4x4 transfer case work with manual hubs. I'm stumped here so any help or advice is greatly appreciated!! Thank You!
Re: transfer case problem
« Reply #1 on: June 24, 2009, 09:20:39 pm »
You need a NP 205 that came off a TH350 along with the adapter that goes between the transmission, and transfer case. Or you can buy a kit that goes into your NP 203 you just installed to convert it to part time.
The only transfer cases offered with full time was the 203.
« Reply #2 on: June 24, 2009, 09:54:09 pm »
