Author Topic: Axels...  (Read 9333 times)
Offline The dream
Axels...
« on: June 26, 2009, 10:53:24 am »
What would be the best front and rear axels for the offroad use? Im talking about having fun in the mud, sand and dirt. Not profesional racing.
Never give up.
Offline fitz
Re: Axels...
« Reply #1 on: June 26, 2009, 11:14:21 am »
Dana 60 front with a 14 bolt F.F. rear seems to be what the hardcore 4x4's run.
Offline The dream
Re: Axels...
« Reply #2 on: June 26, 2009, 02:00:54 pm »
Would a eaton posi be a good choice or stick to the dif ?  ???
Never give up.
Re: Axels...
« Reply #3 on: June 26, 2009, 03:18:59 pm »
Absolutely. But an eaton posi is a diff....
Offline The dream
Re: Axels...
« Reply #4 on: June 26, 2009, 04:19:30 pm »
douh !!  :P
Never give up.
Offline fitz
Re: Axels...
« Reply #5 on: June 26, 2009, 09:09:35 pm »
I run an Eaton posi unit in my 14 bolt S.F., just put it in a few months ago,but so far I love it.
Offline The dream
Re: Axels...
« Reply #6 on: June 29, 2009, 12:06:38 pm »
Sorry about my ignorance but what does SF or FF stand for? and, is it a limited slip? does this sound about right...... EATON POSI GM TRUCK 14 BOLT 9.5 SEMI FLOAT C-CLIP ALL
$558.35 ?
Never give up.
Re: Axels...
« Reply #7 on: June 29, 2009, 01:19:51 pm »
SF = Semi-Float axles
FF = Full Float axles
Offline 79K20
Re: Axels...
« Reply #8 on: June 29, 2009, 02:55:02 pm »
www.coloradok5.com/axleguide.shtml
Dana's and 14-FF's are very desirable for offroading, but it really depends on how much you are going to beat on it. I have seen guys use locked 10-bolts for years of trail riding with minimal breakage, so long as they are careful.
If you are building a rockcrawler or mud truck, you will want better axles. But for plain-jane wheeling, 1/2-ton stuff is fine.
Offline The dream
Re: Axels...
« Reply #9 on: June 29, 2009, 04:47:02 pm »
I should have started from there... i have a k20 3/4... alreday with the 14 bolt and im not building a rock crawler, just your regular fun in the mud/sand. How con i tell if its a FF or a SF?
Never give up.
Offline fitz
Re: Axels...
« Reply #10 on: June 29, 2009, 05:52:31 pm »
If you look at the brake drum the full floater will have bolts holding the axle to the drum. You can see this by removing the hubcap/center cap.
The price sounds right. I paid about $650 including the bearings and install kit.
Offline The dream
Re: Axels...
« Reply #11 on: June 29, 2009, 07:35:29 pm »
I took a look, its a FF. I also found a nice article that explains some basic stuff, if anybody is interested.
http://www.off-roadweb.com/tech/0112or_semi_floating_and_full_floating_axles/index.html
Any tips on having a nice FF rear?   ;)
Never give up.
