Author Topic: Which holes to use for heater core cooling lines?  (Read 7551 times)
Offline Mike Phillips
« on: July 04, 2009, 05:33:01 pm »
The angle between holes 5 and 1 is to sharp.
Would it be alright to connect 5 and 2?
3 will get a 90 degree fitting and go directly to the heater core.
4 will get a straight fitting and go to the heater core.
Then put a plug in hole 1
« Last Edit: July 04, 2009, 05:36:25 pm by Mike Phillips »
Offline Russ130
Re: Which holes to use for heater core cooling lines?
« Reply #1 on: July 04, 2009, 11:08:49 pm »
Personally I'd plug 5, 2 and 1 then use 4 and 3 for the heater core.
« Reply #2 on: July 04, 2009, 11:20:16 pm »
1 and 5 are where they go. You should use the shorter brass fittings. Look at the one on mine...
« Reply #3 on: July 04, 2009, 11:59:12 pm »
show off  ;)
« Reply #4 on: July 05, 2009, 01:00:33 am »
Thanks VileZambonie
I'll check with NAPA about getting some brass fittings.  The steel ones I was testing was all the local speed shop had and I was trying to get parts while I was running errands on Friday.
This project is starting to drain me...
« Reply #5 on: July 06, 2009, 12:58:06 pm »
You should be able to get a molded hose for it, OR the hose off the donor.
I ran a short section of rubber hose on mine for a while.
