Welcome
get more torque from a 305
Topic: get more torque from a 305 (Read 20172 times)
305chevy c-10
August 01, 2009, 08:23:25 am »
hi chevy c10 boys ....i have a 85 chevy c10 with a 305 stock..2.73.gears....what are some upgrades that will give this sleepy motor some go power are any of the following upgrades worth the time a money
hei distrib
edl performer intake
600 holley/carb spacer plate
comp cam (best size to use with stock converter)i was told that putting in a cam without rebuilding whole motor will blow it up ......my goal is that i want this thing to be able to shred the tires 32".....does rear gears have a lot to do with burning rubber
Heartbeat of America yesterday's cheverolet
18T5C10
Re: get more torque from a 305
August 01, 2009, 11:09:25 am »
I wouldn't pump money into a 305 if your goal is tire shredding. Build a 350
eventhorizon66
August 01, 2009, 03:44:04 pm »
The best way increase the torque of 305 is to tear it out and drop a 383 in its place.
But if that's not in the budget and you would still like to modify, stick to improvements that can be transferred over to a 350 when you do get the funds. My first course of action would be a free flowing exhaust, from the exhaust ports to the tail pipes.
As far as engine mods, I am a firm believer that if you want maximum torque from idle to 3000 the stock intake manifold will be your best bet. There are slight modifications you can make to the area immeditely under the carb to improve flow and fuel distribution. They are outlined in this book:
http://www.amazon.com/How-Build-Horsepower-David-Vizard/dp/1884089143/ref=sr_1_2?ie=UTF8&qid=1249158962&sr=8-2
Also, in the same rpm range and where fuel efficiency is still important, the Q-jet is hard to beat, just give it a good rebuild and slap it back on. But if you are interested in 3000-up range (without dramatically impacting the idle-3000 range) and fuel efficiency can take a back seat an Edelbrock performer manifold and carb is a safe bet.
Just keep in mind, as you make modifcations, that your ultimate goal should be to bolt these parts on a 350 or 383.
Also if your ignition is overdue for a tune up then you might consider upgrading the coil and module in the process. Petronix makes a nice little tune up kit for them. And there is a cheap eBay HEI unit that I have heard good things about around here.
Last Edit: August 01, 2009, 09:23:42 pm by eventhorizon66
'85 C10 SWB 350
700R4
TKO600
305chevy c-10
August 08, 2009, 11:38:05 pm »
thanks ...thants about what my hot rod buddy said ....i need to get a 350 ....so basicaly installing a performer intake and holley 600 carb and hei distributor is not worth the time and money as far as getting some extra muscle
18T5C10
choptop
Extended cab fanatic
August 09, 2009, 01:01:04 am »
Here's what ya do. Run some hose from your washerpump to the backtires. Fill the reservoir with bleach when you wanna smokem, push the washer switch to soak the tires with bleach, and let'r rip. It'll accomplish the same thing,lol. Now, if you want to yank the front end off the ground and leave them with their jaws on the ground, the 383 stroker, or a biglock is the way to go. Spinning tires means your sitting still wasting money. I do have a slight addiction to it tho.
Last Edit: August 09, 2009, 01:13:05 am by choptop
August 09, 2009, 03:09:55 am »
rednecks
choptop
August 09, 2009, 02:21:53 pm »
yup
305chevy c-10
August 09, 2009, 05:11:23 pm »
yeah choptop.................i know .....spinning aint winning
18T5C10
screamin86
August 11, 2009, 08:02:16 pm »
Like was said if you want more power do things that can be transfered to a 350 later down the road! Rear gears will help alot too! As will a nice higher stall tq converter! Good combo that worked well in my 82 ta was a 305 with shaved 416 heads summit 1103 cam rpm intake 3500 stall and 3.73s ill prob run the same cam in my 86 k10 when i build a lil motor for it.
86 ta:lm7 hot cam boltons
Donut
August 12, 2009, 07:54:37 am »
I thought by 85 they came with a HEI? IIRC my old 86 had an electronic Q-jet also.
Ever think about some exhaust work? It seems like your concentrating on the intake side.
'73 Chevy K-20 ***SOLD***
350/tbh350/np205
'86 C-30 dually, 454/tbh400
jimbo
August 27, 2009, 01:35:12 pm »
I have the same truck. '85 305 and 2.73's. I plan on doing full exhaust and a gear swap. Beyond that, maybe a performer intake. First and foremost make sure your truck is tuned well, that can help a lot.
Welcome
