Author Topic: what size tires ?  (Read 17168 times)
Offline screamin86
what size tires ?
« on: August 10, 2009, 11:17:46 am »
My 86 k10 long bed has a 3in lift with stock rallys with 31s and well they look like bicycle tires! What can i fit safely and look right/good? Thanks
86 ta:lm7 hot cam boltons
Re: what size tires ?
« Reply #1 on: August 11, 2009, 12:06:33 am »
i dont know if you want to go bigger or what but heres a chart that might help
http://i333.photobucket.com/albums/m387/rebel_cowboy_83/GeneralMotors.jpg
Offline screamin86
« Reply #2 on: August 11, 2009, 12:24:58 am »
sorry i would like to go bigger im just unsure how much i cane safely go. i think 33x12.5 but unsure here is a pic of how the truck sits now. not the running boards and mudflaps will soon be removed!
« Reply #3 on: August 11, 2009, 05:21:56 am »
i would think 33's would fit just right, as far as what with idk I'm thinking 10"
Offline screamin86
« Reply #4 on: August 11, 2009, 09:13:07 am »
Well i believe a 10.5 would be more "economical" or better fit but a 12.5 would look better.
Offline bfofish
« Reply #5 on: August 11, 2009, 10:08:41 pm »
Here is my old K5 with a 3" lift and 33x12.5R15 BFG m/t.
Offline screamin86
« Reply #6 on: August 12, 2009, 01:50:22 pm »
looks good! got any pictures from the side?
Offline bfofish
« Reply #7 on: August 12, 2009, 05:11:53 pm »
Here ya go    and also a pic of my old swb with the same lift and same size tires
« Reply #8 on: August 12, 2009, 09:28:47 pm »
Here's mine with 33x 12.5x 16.5
Offline screamin86
« Reply #9 on: August 12, 2009, 11:52:18 pm »
they all look very nice! i will prob just find a set of used 31 or 33s prefer 33s since i plan on a 14bolt and dana60 within the next year and ill just be doing this all over again lol. my current 31s are pretty worn and dryrotted also missmatched. i need something to drive this winter since the lil lady will most likely have my yukon.
« Reply #10 on: August 14, 2009, 11:27:47 pm »
IMO if your gonging to only use 33's and i don't think your be doing allot of mudding i would stick to a Dana 40, save some money
« Reply #11 on: August 15, 2009, 10:23:29 pm »
If you don't plan to do alot of wheeling the stock ones are fine.
Irish, I assume you meant Dana 44?  It is basically the same as the corporate 10bolt, so there is no need to swap.
Offline screamin86
« Reply #12 on: August 15, 2009, 10:27:11 pm »
well the future plans for this truck (hopefully within the year) it will get a lil more lift and a new motor and i plan to do a few street class pulls a year in local fairs and such and dont want to be braking the stock 1/2ton stuff and replacing all the time. for now i just need something to get me through the winter or untill i begin the swap!
« Reply #13 on: August 15, 2009, 10:38:22 pm »
I would stick with what you have and save up for the D60/14B then.
BTW, you can use a 14B in front, you just have to build it.  Crane Hi Clearance makes the parts for them.  http://www.cranehiclearance.com/
Offline flat black
« Reply #14 on: September 13, 2009, 08:04:49 am »
33/10.50s would be cheaper but 33/12.50 will look much better for sure with that much lift,  since a 4inch 35s rub when turned.  There are many alternatives tho some cut the corners off the front fenders and run 33s stock and 35s with a 2inch but they look a lil stuffed....  I did the d60/14ff on my swb with 39s and it was the best choice ever, take the time and rebuild the 60( king pins, bearings, seals) maybe even invest in detroit lockers they mite help pulling like you spoke about.  A good choice in durable tires when you go bigger would be ground hawg radials they work and last on the street,  6inch lift with 35s sounds good............
« Last Edit: September 13, 2009, 08:10:53 am by flat black »
