Author Topic: DETENT CABLE(KICKDOWN CABLE FOR TH350) 1978 SILVERADO  (Read 5859 times)
Offline kfoz
  • ALWAYS BUILD WITH BRICK & STONE ! ! !
« on: September 01, 2009, 07:13:21 pm »
OK! My dang detent cable BROKE!!!!  It broke at the end where it goes into the trans on my '78 Silvy 350/350!
WHERE can I get an exact replacement. I don't want a universal one!
Thanks guys!
kfoz
kfoz (kfoz@comcast.net)
'73 C20 4 Speed 2WD
Re: DETENT CABLE(KICKDOWN CABLE FOR TH350) 1978 SILVERADO
« Reply #1 on: September 01, 2009, 08:15:21 pm »
Unless you find a used one good luck.
Offline kfoz
« Reply #2 on: September 01, 2009, 08:25:34 pm »
I called O'Reilly Auto Parts. They have NEW ones for $20.00.  They also have universal ones for a temporary fix BUT who the heck would want that?
'73 C20 4 Speed 2WD
« Reply #3 on: September 01, 2009, 08:28:36 pm »
The new ones are not the same as factory.
Offline kfoz
« Reply #4 on: September 02, 2009, 05:57:02 pm »
You are correct. The NEW ones are 5 1/2" longer overall. I contacted a GM dealer and he said as long as the length from the carb mounting bracket is the same, it should work? I don't see how!  I did however install it and we'll see if it works in ANY way.  I still want an original detent cable. I believe it is GM part#1262620  OR 1262618.  PLEASE ADVISE IF ANYONE HAS A GOOD ONE!
kfoz
'73 C20 4 Speed 2WD
