Author Topic: Gauges/Dash problems on my 77!  (Read 5460 times)
Offline daniellegoodman
« on: September 08, 2009, 08:04:38 pm »
So here's the story. Purchased a 1975 tach+gauges off Ebay, to put into my 77. I wanted the tach instead of gas gauge to be in front, so I could get rid of the aftermarket tach on my 77. Well long story short, I plugged the wrong wires and the thing caught fire. Shouldn't be a new problem to get a printed circuit board but I was wondering if anyone knows of any aftermarket wire conversion kits so I don't have to re-wire the thing??
Thanks!!
1977 C10 Cheyenne
Re: Gauges/Dash problems on my 77!
« Reply #1 on: September 08, 2009, 08:35:28 pm »
Just rewire it accordingly.
btw what caught fire?
« Reply #2 on: September 09, 2009, 11:34:16 am »
You cannot put a 73-75 cluster in anything BUT a 73-75 for the exact reason you experienced.  You will have to change the wiring for the 77's VOLT setup to the AMP setup on the 73-75.
Offline Prong
« Reply #3 on: September 09, 2009, 03:53:55 pm »
Order up a 77 printed circuit for it (with the factory tach obviously) , along with a volt gauge. You'll have to move either one or two of the spring clips contacts where the amp gauge plugs into. IIRC, they need to be in the 12 and 3 o clock positions (looking at the back of the cluster). You can look at where the pins need to be on your original cluster to be sure.
79 K10 SB 4x4 383/Th350
79 K10 LB 4x4 350/SM465
