Author Topic: Lifted 2wd Performance??  (Read 4620 times)
Offline Socal_GMC
« on: September 24, 2009, 09:49:11 pm »
Ok does anyone have a lifted 2wd truck they offroad?? i have a 3/4 2wd gmc longbed and i want to do some offroading nothing harsh just moderate. How do you think it will do??
« Last Edit: September 26, 2009, 12:20:23 am by Socal_GMC »
Re: Fabtech lift
« Reply #1 on: September 25, 2009, 06:58:45 am »
Ive got the 1/2 ton arms, and what I am wanting to do ibeef up the ball joint area, and machine it out to accept the 3/4 ton ball joints. The ball joint is the only thing ive been told is different, and I think its just the top one. Havent measure tho.
Offline Benjy_26
Re: Lifted 2wd Performance??
« Reply #2 on: October 06, 2009, 12:13:38 am »
I do it, but not in a Chevy.  I have a 94 ZJ Grand witha 4.0 six that I use for desert blasting and dune running.  I have a mini spool in the rear axle and BFG all terrain tires in 32x1150.  It works well for what it is and hasn't left me stuck (gotta know where to go, though).
Offline maddog
« Reply #3 on: October 08, 2009, 02:32:17 pm »
Paddle tires on back, baldest tallest tires on front, oh ya open up rear end and weld those there spider gears together those there red neck pos works great
Offline velojym
« Reply #4 on: October 08, 2009, 02:42:08 pm »
On my '86 Silverado, I figure the rear is high enough, so I'll eventually look for a set of 3/4 ton springs for the front.
I may one day do a 4x4 conversion, but that's WAY in the future, so I'd like to make this truck as offroad capable as
I can without spending a fortune. I know it's do-able, as I used to offroad my '74 K10 quite a lot... with no front driveshaft.
I don't want to lift it too much, or go with a specialty suspension, as this truck is primarily a hauler, and I don't want to
damage its utility. I suppose I'll need to carefully ensure that I can self-recover in situations that a 4x4 could have gotten itself
out of.
