Author Topic: installing new upper control arms  (Read 9339 times)
Offline gold84gmc
« on: October 21, 2009, 07:27:28 am »
how many pumps of grease do i put in the grease fittings on the shaft?
92 buick century custom 3.3L
Offline Flamingbig10
Re: installing new upper control arms
« Reply #1 on: October 21, 2009, 11:38:36 am »
last ones I did, I filled them up with grease until some started to come out
Offline gold84gmc
« Reply #2 on: October 21, 2009, 07:14:29 pm »
alright thanks...with the grease fitting on the ball joint, where it screws into, there isnt any threads on eather of the control arms i got, are they supposed to be like this or do i have to put my own threads?
Offline Jim Rockford
  • Banned
« Reply #3 on: October 22, 2009, 07:14:52 am »
No the fitting will make its own threads. just screw it in straight. just pump grease in it till you can see the boot start to swell.
1973 k20 Camper special
1980 k20 custom deluxe
2004 Crown Vic LX sport
Offline gold84gmc
« Reply #4 on: October 22, 2009, 01:47:04 pm »
there aren't any threads so i cant screw it in
« Reply #5 on: October 22, 2009, 03:25:16 pm »
Offline gold84gmc
« Reply #6 on: October 22, 2009, 03:30:18 pm »
no the fittings are fine, where they screw into ontop of the ball joints is where there are no threads
Offline Toolmaster
« Reply #7 on: October 22, 2009, 07:46:07 pm »
They could be drive-in zerks. Look and see if the have threads or are they just rings. Put one between fingernail's and twist, if it dont screw out, it's a drive-in zerk.
Offline gold84gmc
« Reply #8 on: October 24, 2009, 05:51:56 pm »
so if its a drive-in zerk then do i just hit it in with a hammer?
« Reply #9 on: October 24, 2009, 05:54:50 pm »
No! Righty tighty! Push inward with your finger while you thread it in.
Offline gold84gmc
« Reply #10 on: October 24, 2009, 09:07:53 pm »
i did and it wouldnt go in....from what i understand a drive-in zerk doesnt have threads it has "rings" around it
  • Banned
« Reply #11 on: November 05, 2009, 06:27:29 am »
take a 1/4 drive socket the size of the zerk, . Then PUSH DOWN as you try and screw it in, it is a self tapping zerk,  no company takes the time to thread the BJ for the zerk. and DO NOT drive it in with a hammer. :'(
You have just been banned for 30 days for that comment.  -ADMIN
« Last Edit: November 05, 2009, 09:48:16 pm by Captkaos »
Offline gold84gmc
« Reply #12 on: November 05, 2009, 02:03:23 pm »
calm down!...not everyone is an expert with everything...and i did exactly what you said and it wouldnt go in
  • Banned
« Reply #13 on: November 05, 2009, 03:39:07 pm »
you might need to put some paper or something to fill up the socket a little bit to keep the zerk from going too far into the socket and not letting you apply pressure..Is the socket bottoming out on the top of the ball joint?
Offline gold84gmc
« Reply #14 on: November 05, 2009, 08:50:06 pm »
nope its not bottoming out, and i used a short socket so it wasnt going up into the socket
