Author Topic: Issues with 3" drop springs?  (Read 8617 times)
Offline y2k_harley
« on: October 23, 2009, 10:59:06 am »
I want to lower my truck as inexpensive as I can.  I need new front coils anyway, so I want to put a pair of 3" lowering coils.  I realize it will probably ride a little rough.  I am wondering if there would be any issues with alignment or clearances.
Re: Issues with 3" drop springs?
« Reply #1 on: October 23, 2009, 12:48:47 pm »
Oh yeah... Your alignment will be toast. You may have wheel /control arm clearance issues. Just get new coils and drop spindles. Do it right the first time. It'll cost you under $300 bucks.
« Reply #2 on: October 25, 2009, 09:20:26 pm »
Personally I don't like springs that lower the truck more than 2", they generally ride like you have a steel rod in there.
Offline y2k_harley
« Reply #3 on: October 25, 2009, 09:54:29 pm »
I was just thinking about 3" springs because they were about $25 cheaper at Summit.  Maybe I will just go with 2".  This truck is my daily driver/work truck.  I don't mind a little inconvience, but don't want to hate driving it.  I had a 2000 F150 that was lowered 3 and 4 that was a blast to drive.  Just had to be careful on driveways.
Offline Flamingbig10
« Reply #4 on: October 26, 2009, 10:03:08 am »
I have 3" summit coils and it rides ok, but it rode better with a 1 or 2 inch djm drop coils I also have 3" djm spindles
Offline y2k_harley
« Reply #5 on: October 26, 2009, 01:22:16 pm »
You have spindles with 3" drop coils?  That thing must be LOW!!  Did you have any install issues with the 3" coils?  Does the quality seem OK on the springs?
Offline oldredtruck
« Reply #6 on: October 26, 2009, 01:45:19 pm »
Oh yeah - it'll ride rough...like a buckboard thru a pasture...
I did 3" spindles and then 2" springs...
too much...
just do the spindles then go from there...the fine folks on here educated me on the cutting of the coils...that's how I am adjusting my height ( using stock springs) and actually I am going up just a tad...driving it now make me wince alot and that's putting undue stress on the steering wheel and puckering the seatcover quite a bit... - we can't be havin that! LOL
85 shortbed...She digs it...
« Reply #7 on: October 26, 2009, 01:47:34 pm »
yes but not low enough though, the lower control arms scrape the ground on uneven payment, the springs are actually ground force
« Last Edit: October 26, 2009, 01:51:22 pm by Flamingbig10 »
Offline bryan103
« Reply #8 on: October 29, 2009, 07:57:16 pm »
i got the summit 3'' springs,i was doing mine and under the original springs there was a metal spacer under it,looked factory,do i reuse them or chunk
Offline team39763
« Reply #9 on: October 29, 2009, 08:16:09 pm »
LOL...that's exactly how I used to feel in my truck.  I hated when my control arms scraped, but then I realized that my oil pan was about the same height or a little lower than my crossmember so I really got nervous about bottoming out.  I ended up putting in better bumpstops and raising the truck up a little.
