Fuel Systems and Drivability
Will a 5.0L injector work ok in a 5.7L?
Topic: Will a 5.0L injector work ok in a 5.7L? (Read 60217 times)
Skunksmash
November 30, 2009, 04:00:25 pm »
I am looking to replace my injectors for cheap if I can. At Autozone/O'rielly's/Napa they are all around $100 each. I found these for a 305:
http://www.shopinjectors.com/injectors/gmc/tb117.htm
Would they work on my 1987 5.7L R10 pickup? Seems like there might not be that much difference between the 5.0L and the 5.7L
Re: Will a 5.0L injector work ok in a 5.7L?
November 30, 2009, 04:14:59 pm »
305 and 350 use different injectors. I got mine from Autozone they were about $79. PN 800-1807N
Skunksmash
December 07, 2009, 05:20:14 am »
Yeah. Not really an inexpensive way out, on this one. Autozone here I come.
Jim Rockford
Banned
December 10, 2009, 08:29:49 pm »
yea the 305 injectors will run lean in a 350 and the computer will throw a fit. Just get the right ones
1973 k20 Camper special
1980 k20 custom deluxe
2004 Crown Vic LX sport
beastie_3
Josh
December 10, 2009, 10:55:58 pm »
There should be no reason to replace injectors unless they are broken. you will save money if you clean them instead.
Semper Fi
Skunksmash
December 13, 2009, 03:35:35 am »
I was kinda thinking about that, but I have ran all the top recommended chemicals through them. Maybe they could be taken out and cleaned somehow? Sounds like it would be difficult though, to not damage the injector when trying to clean it.
December 13, 2009, 04:21:36 am »
i think some shops do it but i think they hook it up, almost like if they were going to flush the trany, but i dont know anything about them i never done nor have i seen it done
Jim Rockford
Banned
December 13, 2009, 06:53:40 am »
best way to do it is take the injectors out and send em in to be cleaned in a ultrasonic bath while they have a harness hooked to em to cycle em while they are in the solution.
Good before and after video
http://www.youtube.com/watch?v=DUPqrgZdIU8
choptop
Extended cab fanatic
December 13, 2009, 08:47:49 am »
Most of the shops that do that type of cleaning around here, wont save you any money. Just get new ones, I dont think you'll regret it later.
December 13, 2009, 09:31:46 am »
I have an awesome fuel injection cleaning system that actually works. It's a 3 part system. Step one cleans the injectors, step two cleans the intake and step three is a solution that goes in the tank. I did it on a Camaro the other day and the guy came back saying his car starts easier, runs better, has way more noticeable power than ever and gets better mileage. I use it quite frequently. Before I invested in it I was skeptical as I've never seen any products work very well in the past but after the last year or so I'm convinced it's not snake oil. I also use their trans and cooling system products/machines. Here's the link
http://www.bgprod.com/products/fuelair.html
Jim Rockford
Banned
December 14, 2009, 12:40:06 pm »
yea BG is good stuff, but it really doesn't do the same amount of cleaning as taking em out and new ones are not a balanced set that you would get back from the cleaners.
Skunksmash
December 15, 2009, 06:55:54 am »
So from the factory, GM made sure that each vehicle got a balanced set of injectors? Kinda makes you wonder about buying new ones, even like a kit that comes with the typical 8 injectors for a newer V8.
Hey vile, which products on that page are part of the system you are talking about? I mean, which ones did you use. You can't really click on them to see their prices.
Last Edit: December 15, 2009, 07:00:45 am by Skunksmash
Reply #12 on:
December 15, 2009, 07:19:38 am »
GM balancing injectors? Yeah right.... You'd have to take it somewhere and have it done as if you wanted to do it yourself you'd have to buy the equipment which is $$$$
Skunksmash
Reply #13 on:
December 15, 2009, 11:27:25 am »
Don't know what all would be involved in balancing injectors. It seems to me that you would be just trying to get two of them with the exact same spray pattern and spray volume, when you got brand new ones. Which would be next to impossible. Or are yall saying that they take two different ones, (non balanced) and then do something to them that balances them?
Reply #14 on:
December 15, 2009, 01:19:21 pm »
They take 2 injectors and match them.
