Author Topic: New Here and My 84 is New to ME  (Read 17742 times)
Offline msc5195
« on: December 13, 2009, 05:14:35 pm »
Just aquirred this 1984 GMC SIERRA CLASSIC. The body is very solid and in rust free. The truck has a freshly built 383 Stroker with a 700R4 trans. Truck has true 2.5" dual exhaust with flowmaster 40's and 3.5" stainless tips. Motor has approx 415-425hp with about 490ftlbs of torque. I am currently in the process of re-doing all of the interior. I have purchased and will be installing a 60/40 split seat from the rear of a 2000 Cadillac Escalade. Seat will be wrapped in two tone leather. All of the door and window seals have been replaced, the door panels have been replaced, the factory tan carpet is being replaced with dark brown carpet, billett dash and door inserts are being added. Here are just a few pics to show the exterior and engine. I will post interior pics in a few weeks when it is complete.
Re: New Here and My 84 is New to ME
« Reply #1 on: December 13, 2009, 06:39:40 pm »
very nice ride!
Offline oldyeller
  • 81 Chevy 3/4 ton
« Reply #2 on: December 13, 2009, 09:31:05 pm »
Beautiful truck.  Welcome from Texas.
1951 Chevy truck
6 extended cab square bodies
Just to name a few
Offline 87OldYeller
« Reply #3 on: December 13, 2009, 11:21:31 pm »
That is nice.
Offline bmaier
« Reply #4 on: December 14, 2009, 12:20:35 am »
Welcome and very nice pickup! Are those chrome rally's on there? Can't quite tell from the pic. They look good.
Offline msc5195
« Reply #5 on: December 14, 2009, 04:26:08 am »
Yes Chrome Rally Wheels
« Reply #6 on: December 14, 2009, 06:56:50 am »
Really nice truck. Is the center section tan, or a metallic champagne color? It looks to have a silverish/gold color in the first pic. It looks great
Offline 69byrd
  • Haulin!
« Reply #7 on: December 14, 2009, 01:38:10 pm »
Sweeeeeet Truck!!!
Offline msc5195
« Reply #8 on: December 14, 2009, 02:17:39 pm »
Center is Tan.
Offline msc5195
« Reply #9 on: December 14, 2009, 02:18:22 pm »
Yes, the center section is tan in color
Offline msc5195
« Reply #10 on: December 14, 2009, 02:19:46 pm »
The Specs on the Engine are:
350 Small Block
2 Bolt Main
400 Crank turned 10 thousandths on Main and Rods
5.7 Rods
3.75 Stroke
Keith Black Hyper Tech Pistons
Speed Pro Rings
Lunati Cam 515 Intake 515 Exhaust
112° Lobe Separation
300 Duration at 50 thousandths
Pete Jackson Timing Gears
Stock Heads with Stronger Springs
Ersen Roller Rockers
415-425 Estimated Horsepower
480-495 Estimated Ft Lbs Torque
Offline eventhorizon66
« Reply #11 on: December 14, 2009, 02:27:51 pm »
'85 C10 SWB 350 700R4 TKO600
Offline msc5195
« Reply #12 on: December 14, 2009, 08:11:27 pm »
:o LOL
 :oOoops........ I mis-spoke or actually the engine builder and/or previous owner mis-spoke when they give me the engines spec sheet but here is more info on the cam that is installed.
Solid roller, rough idle. Excellent street rod or mild bracket race cam with good throttle response. Needs 3000-3500 RPM stall converter, headers, 10.1 or better compression ratio, and 4.10 or better gearing.
•Advertised Duration (Int/Exh): 294/300
•Duration @ .050 (Int/Exh): 259/266
•Gross Valve Lift (Int/Exh): .597/.600
•LSA/ICL: 106/102
•Valve Lash (Int/Exh): .018/.020
•RPM Range: 4000-7200
•Includes: Cam Only
Part Number: 50169
Jobber Price: $354.02
« Reply #13 on: December 14, 2009, 08:29:49 pm »
•LSA/ICL: 106/102
•Includes: Cam Only
Part Number: 50169
Wow, that's freakin' HUGE.  Are you sure about that?  When I put that part number in Summitracing.com I get a significantly tamer Lunati grind.
http://www.summitracing.com/parts/LUN-50169/
At any rate, I gotta hear this beast.
« Last Edit: December 14, 2009, 08:33:18 pm by eventhorizon66 »
Offline msc5195
« Reply #14 on: December 14, 2009, 09:26:34 pm »
•LSA/ICL: 106/102
•Includes: Cam Only
Part Number: 50169
LOOK HERE: http://www.lunatipower.com/Product.aspx?id=1974&gid=285
Am I sure? Well I am no gear head and I am only going on info provided by engine builder. Engine had 748 miles on it when I bought truck. Engine has a very serious lope to it and loves to stop at every gas station it passes. I am getting between 8-10 mpgs as of now.
