The Highs (Raising/Lifts)
4" lift on 84 K20
Topic: 4" lift on 84 K20 (Read 33495 times)
C-Moore502
4" lift on 84 K20
December 14, 2009, 01:09:19 pm »
I am new to this and I just got my 84 K20 6.2 liter diesel. I am curious to know how hard it is to put a lift on a truck and which lift to get. Thanks to all for your help.
84' K20 6.2L "The Duke"
Re: 4" lift on 84 K20
December 14, 2009, 03:01:00 pm »
putting on a lift is pretty involved, how much mechanical work have you done?
C-Moore502
December 14, 2009, 03:43:48 pm »
well I have played around with my power windows and power steering but I have not attempted anything on this scale before. thats why I am asking to see if I am in over my head on this one.
December 14, 2009, 05:04:07 pm »
Not to say you cant do it but get a buddy to help that has done some work but either way your going to have to remove the spring bolts and u bolts they might have to be cut off, had to cut all mine off the steering arm has to be changed there are a couple ways to do it. you have to pick which one to use brake lines have to be changed. Shocks also. What size tire you plane on using? And what do you plan on doing with it?
Last Edit: December 14, 2009, 05:06:11 pm by Irish_Alley
C-Moore502
December 14, 2009, 06:34:04 pm »
I planned on doing it with a friend of mine who has done this dozens of times so I can learn. I am thinking about 35" all-terrains so I can go trail riding and camping with my buddies on the weekends.
December 15, 2009, 01:37:30 pm »
If that is the case, you should be fine with someone with hands on...
December 15, 2009, 08:46:27 pm »
4" with 35's you need to trim the fenders if you want 35s 6" will do with maybe a little fender trimming
C-Moore502
December 15, 2009, 08:48:55 pm »
Sounds like you have done this a few times. Thanks for the wisdom.
December 15, 2009, 09:06:46 pm »
no problem
http://forum.73-87chevytrucks.com/smforum/index.php?topic=12566.0
check that chart out to help
malibu795
January 03, 2010, 03:42:54 pm »
fender trimin is depitced on how much/little backspace/offset you are running.. other words how far out you plan stickign the tire out...
this is a 35x1250 or 315/75/16 ona 16x7" rim with 5.125" of back spacing
adam wildman
75 K25 383/400
jamiebarnesjr3
January 04, 2010, 08:55:13 am »
thats not true about having to trim fenders im running 35/12.50/15 on a stock lift truck 1984 k10 swb 4x4 from canada. and nothing rubs granted tires only have 14 tread left and are very close but they do fit just eat up front end components so i suggest beefing those up
January 04, 2010, 11:07:58 am »
If you are running 35's and didn't trim anything, the truck has a lift on it.
January 04, 2010, 04:38:59 pm »
like chris said you have at least a 6" lift
malibu795
January 04, 2010, 08:17:54 pm »
Quote from: Captkaos on January 04, 2010, 11:07:58 am
then please explain my pictures?
adam wildman
75 K25 383/400
Josh454
January 04, 2010, 09:15:20 pm »
Certainly no lift in the pics! Although I see you have the 3/4 ton 3 leafs that gives about an inch or so. I personally feel those charts are pretty worthless. It's all how you use your truck. I buddy of mine had a street only truck and would drive around with stock ride height and 35's too. He couldn't turn the wheel wheel to half lock on even pavement without some serious rubbing...but he did it! On the flipside there are people out there with 6" and 33's because they twist up real good. I ran 35's and 4" with very very minimal fender triming. It was fine for mud and street.
4" lift on 84 K20
