Author Topic: Stuck steering arm  (Read 23128 times)
Stuck steering arm
« on: December 29, 2009, 09:02:24 pm »
I am in the process of replacing my steering on my 79 K10 and I can not get the steering arm off. I took the 3 nuts off and soaked the studs in wd40 and PB and the thing just wont come off. I have even placed a jack under it to try to get it off and no luck. The only thing I havent tried is heat because I dont have a source. Any help???
Re: Stuck steering arm
« Reply #1 on: December 29, 2009, 09:06:26 pm »
Did you remove the washers? IF you don't have a torch get a small MAP torch. Use a BFH (3lb) and shock the steering arm.
Offline Josh454
« Reply #2 on: December 30, 2009, 09:32:47 pm »
Yep, exactly.  Need lots of heat and hammering.   ;)
« Reply #3 on: December 30, 2009, 09:40:32 pm »
It is my understanding that there are cone shaped shims that slide down the studs to take up the space. My new steering arm holes are beveled. That is all i see when the nuts are off. Ill go back and try again. Ill see if I can round up a bigger hammer.
« Reply #4 on: December 30, 2009, 09:49:59 pm »
If you did not remove the conical washers then that is your problem.
« Reply #5 on: December 30, 2009, 09:53:33 pm »
They are almost flush with the top of the arm and I am almost positive it hasn't been touched since the factory. What would be the best way to get them out? Should I try to remove the studs?
Offline dirtmod0
« Reply #6 on: December 31, 2009, 06:20:05 pm »
only way to do it is use heat and a lot of it, it took about an hour with air hammer and shops torch and finally rattled the washers out. I put the air hammer right beside the washers rattled the heck out of it and it finally started to move up.
« Reply #7 on: January 01, 2010, 11:48:20 am »
Clean the area around the studs and soak it with penetrating oil. Heat them up and try working them loose with a hammer and punch first. Shock the arm with a bfh, put the nuts on too to protect the threads. an air hammer will help too.
Offline 79scottsdale
« Reply #8 on: January 01, 2010, 09:31:57 pm »
Ditto, worked for me.
Working on the truck with my son.........Life doesn't get any better than that!
1979 Scottsdale C10 4X4 (We are the second owner.)
Offline captain carnage
« Reply #9 on: January 02, 2010, 11:35:38 pm »
I have taken an an angle grinder to the arm itself, where it meets the knuckle, and ground away at the arm untill I could get a punch in there. Then I whacked away with a hammer until eventually the cone washers popped up and the arm freed itself. The name of the whole game is just determination no matter what method you use.
Offline bmaier
« Reply #10 on: January 03, 2010, 02:16:11 pm »
« Reply #11 on: January 03, 2010, 11:56:42 pm »
Ok thanks guys, Ill let you all know when I get it done. Do parts stores carry the conical washers and/or studs if/when I damage them? Or will I be needing to order them from a specialty store? I have lost the conical washers when I got the steering arm a few years back.....Doh
Offline bmaier
« Reply #12 on: January 04, 2010, 01:08:31 am »
I got mine from the local Chevy dealership, they were pretty cheap if I remember right.
« Reply #13 on: January 22, 2010, 06:17:25 pm »
« Reply #14 on: January 22, 2010, 08:07:10 pm »
Would these work? http://www.partsmike.com/store/store.php?crn=204&rn=1314&action=show_detail
I know its for a D44 and I have 10 bolt, but externally they are similar.
