Author Topic: Is it bent?  (Read 26789 times)
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
Is it bent?
« on: January 16, 2010, 04:28:56 pm »
I noticed that even though the frame was found to be straight, the truck still had a bit of lean to it from straight behind.  I thought maybe I had a saggy spring, but it wasn't sagging before it got wrecked.  so i was under there looking and it looks to me like one of the axle tubes is bent.  Check out the pic, I put a straight edge on my computer screen and it's way off.   When it got hit for a while the only wheel on the ground was that one, so it had to have taken a good bit of force.
I noticed it driving up from behind the truck in the car, it didn't look right.
Am I wrong?  Looks to me like I need a new Axle assembly, or is there anyplace that straightens those things?
« Last Edit: January 16, 2010, 04:31:17 pm by 78 Chevyrado »
Offline three8six
Re: Is it bent?
« Reply #1 on: January 16, 2010, 05:50:29 pm »
I would say the left one definetely appears bent. Im no expert though.....
Offline thirsty
    • Suitor's Garage
Re: Is it bent?
« Reply #2 on: January 16, 2010, 07:20:52 pm »
Regular thing to check them and replace axle tubes in race shops. I have seen them straightened but once bent they usually replace them.
Offline bobcooter
  • 1979 Scottsdale C-20
Re: Is it bent?
« Reply #3 on: January 17, 2010, 06:03:07 pm »
 I agree.
« Last Edit: January 17, 2010, 06:33:29 pm by Captkaos »
Re: Is it bent?
« Reply #4 on: January 17, 2010, 08:19:35 pm »
It does look bent in the pic but it could be an illusion too. Take a piece of string from left to right in the same spot and measure off the string. If it's bent I would just grab a used one.
Offline HAULIN IT
Re: Is it bent?
« Reply #5 on: January 17, 2010, 10:05:05 pm »
Kenny, The best, surest way to know is to get a 4 wheel alignment. The print out will show you toe, camber & thrust angle of the rear axle. Lorne
« Last Edit: January 17, 2010, 10:07:13 pm by HAULIN IT »
Re: Is it bent?
« Reply #6 on: January 18, 2010, 07:55:46 am »
I wouldn't waste $ on an alignment if you can tell right off the bat with a simple measurement. If it is bent an alignment will just show that you have set back and you'll have to pay for an alignment twice. The lignment won't reveal what parts are damaged either.
Offline HAULIN IT
Re: Is it bent?
« Reply #7 on: January 18, 2010, 06:44:50 pm »
Vile, While I agree a string used correctly doesn't lie. I was thinking a little more into it. He mentioned "the frame was found to be straight" & "it wasn't sagging before the accident". If there is an Third party paying (insurance company maybe?) they are most likely going to want some "proof" that something is wrong before they pay. To me, it is golden to have specs show "Yes, this is bent...See here in Red?" Before you start talking. To me, it would be will worth the $50, If it's a matter of him paying for the whole repairs, I wouldn't want to bet the farm on possably a mis-diagnosed un-needed item.
I ask you to think about that a little more...If the Left wheel spec shows, say -.9 toe & the Right side shows .01, the axle housing is bent back on the Left. Now if the Left is -.9 & the Right is .9...Now we're dealing with a thrust angle problem...the frame is diamond, spring, hanger, ect. problem & not the axle housing.
 If the Left wheel shows very much camber at all, the housing is bent.
 All of this ASSUMES that a reading is again taken with the axle shaft rotated 180* after the initial readings to verify. Following me?
 Can it be found with a level, square & a string? Yes it can if you know what your trying to accomplish & how to go about it. My Two Cents worth, Lorne
  • Z62 ON-ROAD
Re: Is it bent?
« Reply #8 on: January 18, 2010, 08:03:23 pm »
I'll go a bit more into the frame being straight.  No there was no third party paying for it.  I did get money from insurance, but I put in more myself to go ahead and repaint it with new interior and all trim items.
When I took the truck up to begin with after the wreck, the frame wasn't quite straight, turnes out to be a combination of the bent fender pulling the core support back and down 1" both directions, and also a couple of the cab-mounting bolts were bent.  I was up there when they pulled the fender and cut the bad cab bolts, and when they removed both of them you could see the truck settle a bit from the tension on it.   They took all kinds of measurments and found the frame to be ok with the tension removed.   The only thing they had to pull on, was the front right lower cab corner to get it back out so they could put the new front half of the rocker panel on.
That axle did get a good bit of stress in the wreck.  It dang near turned the truck over, and for a bit only the rear right wheel was on the ground.  If it had caught on anything when it slid it would have turned over.  couldn't see nothing but sky out the passenger side window.  So I'm thinking it must have bent then.  I really couldn't tell anything before the body shop, cus the front was real crooked and the cab  setting cocked on the frame.  I think I probably just missed it in the excitement of all the other stuff I got to do to the truck.  If it is bad, it'll be the only thing so far that got missed, so I can definately handle that.
As far as who will pay for it, it'll be me.  It's been too long and it's really not too bad costwise.  (since I did get so much done to the truck ;D )
I usually back in when I park so when I drive in in the car, it looked ok from the front.  One day I parked in there front first and when I drove up in the car, the left tire looked leaned in at the top compared to the right tire.  Well after a couple of days it got to bugging me so I checked it as best I could.   I havent Jacked it up to measure the width on 3 sides of the tire yet though (3 oclock, 6 oclock, 9 oclock).  That's next.  I didn't get out there today, had to go look at houses.
I'm wondering about the string thing, I've tried to do that, but either the shock mounts or the pumpkin get in the way.  No matter how I've eye balled it though, it does look crooked, even from the front, under the engine.  Look at the u-bolts too, They are 90* to the axle tube.
I follow you lorne, about getting the alignment check.  Actually I think alignment checks are free  at kauffman so that's shouldn't be a big deal.  It costs to adjust it but not to check it.  I'm wondering why to rotate the axle shaft 180*  If it is the axle housing tube, what will that do?  Wouldnt that show a bent axle shaft on a semi floater?   I'll see about getting it checked out.  I should have all the stock specs in my manual.  I'll hunt em up.
Thanks for the good relies fellas!
« Last Edit: January 18, 2010, 08:08:05 pm by 78 Chevyrado »
Offline team39763
Re: Is it bent?
« Reply #9 on: January 18, 2010, 09:12:24 pm »
How hard is it to replace axle tubes?  Is it the same for a 10bolt?
Offline Layne
Re: Is it bent?
« Reply #10 on: January 18, 2010, 09:21:19 pm »
Just thought of this- and correct me if I'm wrong- How does the wear pattern look on the questionable tire?
  • Z62 ON-ROAD
Re: Is it bent?
« Reply #11 on: January 18, 2010, 09:29:36 pm »
The tires are too new to tell, and i did'nt think to check the old tires.   The new ones only have about 1500 miles on em and they have been rotated once since then cuz the tires guys didn't get em balance right.
  • Z62 ON-ROAD
Re: Is it bent?
« Reply #12 on: January 18, 2010, 09:30:56 pm »
I'd think it would be cost effective to just buy a new rear end.  i think I bought a 10 bolt once for $75 at a local salvage yard.
Though I'd like to do that on mine or straighten it since it's all in EXCELLENT shape.
Re: Is it bent?
« Reply #13 on: January 18, 2010, 09:32:51 pm »
Haulin-it I definitely agree with you on checking alignment angles but... I have a state of the art Hunter system and I know how to use it very well. Unfortunately I find that 85% of the shops out there have the dumbest of the dummies working their aligners and live by the whole set the toe and let it go philosiphy. If it was an insurance job I'd agree get an alignment from a reputable alignment shop but once again if you're bent you're bent and it's kinda pointless. If his total toe is incorrect in the rear it would indicate a bent axle tube as if it was in the hub or wheel it would have excessive runout. Camber would also point this out however if he has set back or a bent hanger, damaged main leaf etc this won't be evident until he puts a straight axle back in there (that's what I meant by my earlier statement regarding the alignment not telling him what parts are bent) Just replace it with a used unit then get an alignment.
  • Z62 ON-ROAD
Re: Is it bent?
« Reply #14 on: January 18, 2010, 09:37:32 pm »
I just had a thought.  I think tomorrow I'll go out there and put the angle locator on each axle tube.  they won't be level, but as long as they show the same angle, everything is fine?  Sound like a good idea?
This is what I have:
I hadn't thought about the spring, Vile.  Whats a good way to check them to see if they are even?  Jack it up by the frame until the suspension is hanging and measure fron the axle mounts to the bed floor or a frame reference?   Or do I have to have the axle unbolted from it, or will this do anything at all?
« Last Edit: January 18, 2010, 09:45:43 pm by 78 Chevyrado »
