Author Topic: The Citation needs Nicorette!  (Read 9693 times)
Offline Layne
« on: January 23, 2010, 04:47:51 pm »
Let me give you guys a little background... I inherited the car in Oct. '04. It had been sitting for about 6 years. I put a new battery in there and it fired right up. I started it about once a week for 3 years until it became my daily driver. It's always used a little oil between changes (about a quart). At first, I got a dab of oil in the air cleaner assembly, but I started using Lucas every oil change and that's a non issue. The car has no cat, and a fart can. ::) It's always had this erratic idle, but that's a non issue, too. Last summer it'd smoke terribly going down hill in 4th after I gassed it. Valve seals??? Smokes on start up too.  I retired it at the end of last summer when I bought my headache sierra. Well, this is a restoration in progress, and I'd like to get it to stop smoking before I start body work.  Oh yeah, I got with 50,000 miles and now have almost 90,000 on it. Heres my dilemma-
Comp test- #1 155 psi wot
                #2 120
                #3 145
                #4 150
Vac. test   17-19 in at idle. Usually 19, but that's where my erratic idle comes it.
I'm thinking valve seals, but I wouldn't doubt the rings either. My grandpa drove this really nice and I was sixteen when I got it. I don't really drive it so nice. :D
On a side note, I don't know if it's related my aftermarket temp gauge goes to 230 F before the electric fan comes on to bring it down to 190. The fan never, ever comes on going down the road in the summer, and it runs at 195 all the time, unless I idle for a while. I'm a stickler for scheduled maintenance on this car, too.
SO- Rings, Valve seals, or Head gasket???
Re: The Citation needs Nicorette!
« Reply #1 on: January 23, 2010, 05:44:42 pm »
What color is the smoke? Pull the vacuum hose off of the vacuum modulator and see if there's any transmission fluid present.
Offline Layne
« Reply #2 on: January 23, 2010, 05:46:49 pm »
It's a stick. It's whitish. It's oil for sure. Never had an antifreeze leak/burn
« Reply #3 on: January 23, 2010, 05:49:30 pm »
White smoke is coolant or automatic transmission fluid
Offline Layne
« Reply #4 on: January 23, 2010, 05:55:38 pm »
It doesn't smell sweet or anything. Why would it only smoke at start up and gassing it after going downhill for a while? I figured a head gasket leak would smoke all the time. It's never, ever been low on coolant. Just oil. And my oil turns jet black after 500 miles.
« Reply #5 on: January 23, 2010, 05:57:34 pm »
Oil smoke is bluish grey
Coolant and ATF is White
Rich fuel mixtures is black smoke
Offline Layne
« Reply #6 on: January 23, 2010, 06:09:51 pm »
I just fired it up, and it's bluish I'd guess. Maybe all that condensation is throwing me off. You know the steam from the exhaust in the winter.
Offline Layne
« Reply #7 on: January 23, 2010, 06:39:14 pm »
Plug num 1 was orangish. 2,3 and 4 were the grayish good burning color. If that helps any
« Reply #8 on: January 24, 2010, 04:19:18 am »
so the smoke at start up could that just be condensation?
Offline Layne
« Reply #9 on: January 24, 2010, 04:55:58 pm »
I first noticed it starting in the summer. But the condensation was throwing me off now. I noticed it in the summer, but never really paid attention to the color.
Offline Marc
« Reply #10 on: January 24, 2010, 05:45:18 pm »
It'd be a good candidate for a 2.8, 3300, or 3800 transplant!  Valve seals I would think would be the most likely candidate if it smokes on startup  and if my memory serves coasting downhill with your foot off the pedal causes a high vacuum situation in the intake tract, allowing it to suck in oil through the valve guides, but I could be wrong.
Offline Layne
« Reply #11 on: January 24, 2010, 06:12:33 pm »
I was thinking about the caddy 4.9L  :o 8)! But that's for another day. I know you can do valve seals on the motor, but can you do valve guides too?
« Reply #12 on: January 24, 2010, 09:00:45 pm »
Ive done the seals, but I dont think the guides can be done.
Offline eventhorizon66
« Reply #13 on: January 24, 2010, 10:25:24 pm »
You can't replace/recondition valve guides with the heads on the engine.  Is that what you're asking?  That's a job for the machine shop.
'85 C10 SWB 350 700R4 TKO600
Offline Layne
« Reply #14 on: January 24, 2010, 10:32:11 pm »
Event- yeah. That stinks. Is it pricey?
