Author Topic: Flip kit ?  (Read 7411 times)
Offline Lucky73
Flip kit ?
« on: February 10, 2010, 08:36:54 pm »
So I here more and more about the flip kit.I just want to know much it actually drops it,and do you have to notch the frame?
73 Chevy C10
73 GMC K20
93 Chevy S-10
Offline biscuit41
Re: Flip kit ?
« Reply #1 on: February 11, 2010, 08:42:23 am »
It will lower the rear of your truck the thickness of your axle+leaf pack.  I didn't have to use a c notch on mine but you may have to depending on the clearance...
1985 C10 Longbed
Re: Flip kit ?
« Reply #2 on: February 11, 2010, 10:05:35 am »
If your rear springs still have a good arch you can get away without the C-notch.
Offline three8six
Re: Flip kit ?
« Reply #3 on: February 11, 2010, 11:43:12 am »
I cut the factory bumpstop and bracket off, and bought a bumpstop that was like 3/4 of an inch and put it directly on the frame just in case it does hit.....
Offline biscuit41
Re: Flip kit ?
« Reply #4 on: February 11, 2010, 03:23:52 pm »
My flip kit came with one.  I'm sure they are only a couple of bucks...
1985 C10 Longbed
Re: Flip kit ?
« Reply #5 on: February 11, 2010, 04:57:44 pm »
Expect about 5-7" of drop with a flip.
Offline Lucky73
Re: Flip kit ?
« Reply #6 on: February 12, 2010, 12:48:13 am »
Thanks I may consider doing this
73 Chevy C10
73 GMC K20
93 Chevy S-10
Offline Flamingbig10
Re: Flip kit ?
« Reply #7 on: February 12, 2010, 10:59:18 pm »
When I had 3 leafs the flip lowered it almost 8" and when I added 2 leafs back it raised the rear up 3", I used a beltec flip kit with c-notch
