Author Topic: transmission  (Read 4879 times)
Offline hotrod24
transmission
« on: February 17, 2010, 08:25:30 pm »
hey I have a 350 tranny out of a 78 chevy truck would it work in a 95 blazer?
1978 pontiac grand prix...
Re: transmission
« Reply #1 on: February 17, 2010, 09:00:58 pm »
No, 95 would have a 4L60. They are controlled by the ECM.
Offline hotrod24
Re: transmission
« Reply #2 on: February 17, 2010, 09:29:23 pm »
thanks blazin
Offline flaminchiten
Re: transmission
« Reply #3 on: February 17, 2010, 10:23:20 pm »
Anything will work with enough time and money...would it be worth it....no
Re: transmission
« Reply #4 on: February 19, 2010, 12:15:45 pm »
why would the ecm have to be plugged in if the 350t has no ecm to plug into? i can understand putting the 4l60e into a 79 you need the ecm but the other way why would you need it?
Re: transmission
« Reply #5 on: February 19, 2010, 03:11:17 pm »
It will through a code.
Re: transmission
« Reply #6 on: February 19, 2010, 03:41:23 pm »
Assuming you are talking about a T10 Blazer, in 1995 it used a 4L60E. A TH350 4wd trans will not be a direct swap. You could make it work if you really wanted to.
